ADOBE ANIMATE
I'm new to coding and I don't understand it. I'm using AS3 and i'm trying to make a pause and play button in my game so I typed in this code:
yourButton.addEventListener(MouseEvent.CLICK, pauseGame);
function pauseGame(e:MouseEvent):void{
stage.frameRate = 0;
yourOtherButton.addEventListener(MouseEvent.CLICK, resumeGame);
function resumeGame(e:MouseEvent):void{
stage.frameRate = 15;
and it's giving me errors:
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 142, Column 8 | 1120: Access of undefined property yourButton. |
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 142, Column 54 | 1120: Access of undefined property pauseGame. |
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 147, Column 5 | 1120: Access of undefined property yourOtherButton. |
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 147, Column 56 | 1120: Access of undefined property resumeGame. |
I don't know what this means...
(the part that is in Bold is the code it has a problem with) The full code is:
package{
import flash.display.MovieClip;
import flash.events.KeyboardEvent;
import flash.ui.Keyboard;
import flash.events.Event; //used for ENTER_FRAME event
import flash.events.MouseEvent;
public class Main extends MovieClip{
//constants
const gravity:Number = 1.5; //gravity of the game
const dist_btw_obstacles:Number = 300; //distance between two obstacles
const ob_speed:Number = 16; //speed of the obstacle
const jump_force:Number = 15; //force with which it jumps
//variables
var player:Player = new Player();
var lastob:Obstacle = new Obstacle(); //varible to store the last obstacle in the obstacle array
var obstacles:Array = new Array(); //an array to store all the obstacles
var yspeed:Number = 0; //A variable representing the vertical speed of the bird
var score:Number = 0; //A variable representing the score
public function Main(){
init();
function init():void {
//initialize all the variables
player = new Player();
lastob = new Obstacle();
obstacles = new Array();
yspeed = 0;
score = 0;
//add player to center of the stage the stage
player.x = stage.stageWidth/2;
player.y = stage.stageHeight/2;
addChild(player);
//create 3 obstacles ()
createObstacle();
createObstacle();
createObstacle();
//Add EnterFrame EventListeners (which is called every frame) and KeyBoard EventListeners
addEventListener(Event.ENTER_FRAME,onEnterFrameHandler);
stage.addEventListener(KeyboardEvent.KEY_UP, key_up);
private function key_up(event:KeyboardEvent){
if(event.keyCode == Keyboard.SPACE){
//If space is pressed then make the bird
yspeed = -jump_force;
function restart(){
if(contains(player))
removeChild(player);
for(var i:int = 0; i < obstacles.length; ++i){
if(contains(obstacles) && obstacles != null)
removeChild(obstacles);
obstacles = null;
obstacles.slice(0);
init();
function onEnterFrameHandler(event:Event){
//update player
yspeed += gravity;
player.y += yspeed;
//restart if the player touches the ground
if(player.y + player.height/2 > stage.stageHeight){
restart();
//Don't allow the bird to go above the screen
if(player.y - player.height/2 < 0){
player.y = player.height/2;
//update obstacles
for(var i:int = 0;i<obstacles.length;++i){
updateObstacle(i);
//display the score
scoretxt.text = String(score);
//This functions update the obstacle
function updateObstacle(i:int){
var ob:Obstacle = obstacles;
if(ob == null)
return;
ob.x -= ob_speed;
if(ob.x < -ob.width){
//if an obstacle reaches left of the stage then change its position to the back of the last obstacle
changeObstacle(ob);
//If the bird hits an obstacle then restart the game
if(ob.hitTestPoint(player.x + player.width/2,player.y + player.height/2,true)
|| ob.hitTestPoint(player.x + player.width/2,player.y - player.height/2,true)
|| ob.hitTestPoint(player.x - player.width/2,player.y + player.height/2,true)
|| ob.hitTestPoint(player.x - player.width/2,player.y - player.height/2,true)){
restart();
//If the bird got through the obstacle without hitting it then increase the score
if((player.x - player.width/2 > ob.x + ob.width/2) && !ob.covered){
++score;
ob.covered = true;
//This function changes the position of the obstacle such that it will be the last obstacle and it also randomizes its y position
function changeObstacle(ob:Obstacle){
ob.x = lastob.x + dist_btw_obstacles;
ob.y = 100+Math.random()*(stage.stageHeight-200);
lastob = ob;
ob.covered = false;
//this function creates an obstacle
function createObstacle(){
var ob:Obstacle = new Obstacle();
if(lastob.x == 0)
ob.x = 800;
else
addChild(ob);
obstacles.push(ob);
lastob = ob;
Message was edited by: JSM (Discussion successfully moved from The Lounge to Adobe Animate CC - General)
try:
package{
//constants
//variables
init();
yspeed = 0;
score = 0;
addChild(player);
createObstacle();
createObstacle();
createObstacle();
function restart(){
obstacles = null;
obstacles.slice(0);
init();
//update player
yspeed += gravity;
player.y += yspeed;
restart();
//update obstacles
updateObstacle(i);
//display the score
if(ob == null)
return;
ob.x -= ob_speed;
changeObstacle(ob);
restart();
++score;
ob.covered = true;
lastob = ob;
ob.covered = false;
if(lastob.x == 0)
ob.x = 800;
else
addChild(ob);
obstacles.push(ob);
lastob = ob;
I tried the code and it got rid of two of the problems in it, but it still has two more problems.
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 48, Column 4 | 1120: Access of undefined property yourButton. |
M:\Sweeting, Noah\Labs\Final\Better Flappy Bird\Main.as, Line 49, Column 5 | 1120: Access of undefined property yourOtherButton. |
then you didn't create those two objects. i can see they're not created with code so they should be created on frame 1.
I have created them as buttons and it started to work but now the buttons don't do anything.
what do you mean by, '... it started to work'?
The game now works but the buttons don't.
use the trace function to debug. eg, are your button listener functions called?
You need to give the buttons instance names.
I did give them instance names
