Hi all
I have the reverse (sort of) for a query I raised a few months ago.
I'm starting to do more and more book interiors and have a requirement to add a scene break (asterisk symbol) before all untabbed paragraphs.
To explain: basically the author had been using untabbed paragraph styles to 'suggest' in-chapter scene breaks, but that 'scene break' now needs to be more obvious. Hence the need to insert a centred asterisk, with its own paragraph style, before all paragraphs that carry an untabbed paragraph style.
To illustrate...
This:
Needs to become this:
I'm embarrassed to say I'm still grappling with GREP for certain things, so any suggestions appreciated.
BTW, if it helps, the paragraph style I have available for targeting are:
Normal-untabbed (for the untabbed paragraph)
Scene Break (for the asterisk paragraph)
There may be an easy answer to this but, today, it's escaping my brain.
Thanks in advance
M
Maybe this:
You would need another F/C to apply proper parastyle to the asterisk.
Maybe this:
* and Grep are the Past!
Play Smiley and Para style is the Future!!
Hi Winterm
Yep: that works!
Agreed: will have to do another find / change to apply the asterisk / scene break paragraph style.
Will also have to do a manual sift to remove those breaks that are inserted where they don't need to be (e.g.: after chapter headings / before first chapter paragraph).
But that's a great help.
Many thanks!
VBW
M
You mean 'double' breaks? Oh, don't do it manually.
You can start trying in F/C Text tab: ^p^p change to ^p
If I got you right and this is that simple.
If you don't like smileys and really want to play it with Grep, just copy an "asterisk para" and play this simple regex: it will insert the "*" para before each "Blue" para!
Hi Obi
I'll try that option out a little later today, too.
Thanks for the suggestions!
VBW
M
PS: Loved your work during the Clone Wars
