Same plugin with same version loading in some systems and some system giving error message............
Engaged ,
May 03, 2017 May 03, 2017
Hello Friends,
I am using Illustrator CC 2015 (version 19.2.1).
I create a plugin for 64 bit system named is ResizeArt.aip.
I putting this plugin in this path
In some system its loading and working properly.
But In some system with the same version of illustrator  it's giving error message like this
Only difference in both system is one system has the Visual studio 2013 (developed plugin version ) plugin working with this system and other system has no Visual studio installed with this not Visual studio 2013 installed.
so I am stuck why it's not working with other system ?
so Please assist me.
Thanks & Regards
Kundan
SDK
643
Adobe
Adobe Employee ,
Hi Kundan,
You could try installing the Visual Studio 2013 runtime on the machine on which plugin is not loading.
Advocate ,
Alternatively, compile your plugin using the static versions of the runtime libraries so you don't need to worry about installing the runtime dlls on other machines.
Engaged ,
May 04, 2017 May 04, 2017
Hello LeoTaro,
Some DLL files(msvcr120d.dll , msvcp120d.dll) are missing into the other system thats why it's was giving
that error message after putting these files on this path C:\Windows\System32
the not showing error message and showing and working the plugin in ai cc 2015 (version 19.2.1) properly.
Regards
Kundan
Advocate ,
Yes, those are the microsoft runtime dlls. If you build your plugin with the dll version of the runtime libraries, you will need to install these on any machine that doesn't already have them (you should use the microsoft runtime installer rather than copying them manually). If you build your plugin using the static version of the runtime libraries, you don't need to worry about these dlls.
Adobe Employee ,
Hi Kundan,
The dlls that you've mentioned as missing are debug versions (notice the 'd' at the end of the dll names).
Are you using the debug version of the plugin? Or perhaps you are linking with some component that has been compiled for the debug configuration?
You shouldn't see this if you use the release configuration.
Akhil Jindal
Engaged ,
Thanks Akhil and LeoTaro,
I am trying to do same as you suggest LeoTaro , then I will update here.
Regards
Kundan
Engaged ,
Hello LeoTaro,
I try to compile plugin as static version of runtime library , but problem is still same.
Regards
Kundan
Engaged ,
Thanks for reply LeoTaro,
I tried to compile plugin as static as you suggest but it didn't work i mentioned above .
When I copied and paste both dll manually then it's working.
It may be possibe I can do anything wrong with static compile , but now after copied It's working.
Thanks & Regards
Kundan
Engaged ,
Thanks for reply Akhil,
Yes, I am using the debug version of plugin.
Regards
Kundan
