Hi ! I have a big problem with Adobe After Effects... I can't use it anymore since about a few days... When i deleted it and reinstalled, I had that error rapport :
Exit Code: 184
-------------------------------------- Summary --------------------------------------
- 2 fatal error(s), 0 error(s), 2 warnings(s)
FATAL: Error (Code = 184) executing in command 'MoveFileCommand' for package: 'AdobeAfterEffects14AllTrial', version:14.2.0.199
FATAL: Error occurred in install of package (Name: AdobeAfterEffects14AllTrial Version: 14.2.0.199). Error code: '184'
WARN: adobe_caps.dll
WARN: Unable to move file at "C:\adobeTemp\ETRB5F0.tmp\1\universal\Professional\Support Files\32\adobe_caps.dll" to "C:\Program Files\Adobe\Adobe After Effects CC 2017\Support Files\32\adobe_caps.dll" Error 32 Le processus ne peut pas accéder au fichier car ce fichier est utilisé par un autre processus.. Try setting correct permissions to the specified file/folder or parent folder, so that admin has rights to modify it.
Please help me ! (sorry for my bad english ^^) Thanks all !
Resolved ! I finally tried to "manually" download an older version of After Effects (AE 2015), I ran it, it worked, then I tried to run AE 2017 again and it worked. I didn't understand why it worked haha but I'm very happy now. Thanks to Szalam for his useful help !
Have you tried following the directions?
The easiest thing to do would be to run After Effects as an administrator.
Hi Szalam.
First, thanks for your interest ! I'll test starting AE with this condition but before, I have to succeed download of AE ^^ (cf: error code on my first message). Have you any idea ?
Thanks again
Sorry, I meant the CC app.
Okay, no problem
I just tried and I'll send you the rapport when the download will be finished.
Ok, always the same error. I also tried delete %temp% files.
I've succeeded installing AE but when I run it, I can see the startup screen but no response...
Please help me
Glad to help!
