Converting text frames to text field using scripts - edited for brevity.
May 04, 2017 May 04, 2017
I am using Indesign cs6. I want to make interactive Pdf  using the Text Frame can convert into Text Field. I can be done manually(see above Image), but i need to make the same thing by using scripting. i don't know how to do using scripting anyone please help me.
[Discussion Moved to InDesign Scripting Forum by Moderator]
[Correct Answer changed by Moderator]
Scripting
2.2K
Community Expert , May 04, 2017 May 04, 2017
Hi Sangeetha,
surprisingly I found no direct method for converting a text frame or something else to a "Text Field" (in scripting terms: object textBox) by scripting. I could be wrong, but maybe the developers did not provide that when form fields were introduced.
What is working is using the menu command for this by scripting.
For that you'll need a selected object in the document to start with.
Here an ExtendScript (JavaScript) script snippet that will do this for one single item selected:
// Text
Advisor ,
You have posted this in the main InDesign Forum. I will move this to the InDesign Scripting Forum so that you can receive more technical help.
Best,
EW
Hi Sangeetha,
// Text frame, rectangle, oval or polygon should be selected:
var sel = app.selection[0];
// Menu command "Convert To Text Field":
var convertToTextField = app.menuActions.itemByName("$ID/$$$/Command/TextField");
// If available:
if(convertToTextField.enabled)
    convertToTextField.invoke();
( This will not work with InDesign Server. )
Uwe
Thank you so much
Advisor ,
Sorry sangeethak65390815 - But it was Laubender​ answer that was actually correct. I just moved this to the appropriate forum.
That's certainly helpful of me to do so but not correct or fair to Laubender who has given you a very detailed and helpful answer.
Best,
EW
Its ok and thanks for your response
Jul 30, 2019 Jul 30, 2019
Top,
Thank you so much
