Hi, I'm using ID CS4, I need to find all words in the paragraph like this: Any Two Or More Words followed by body texts onwards.
Can anyone pls help, thanks.
Lily
To find 2 or more capitalized words, use this GREP:
\b\u\w+(\s+\u\w+)+
Lots of escaped codes! Let's go through them one at a time.
The first \b is a word break. In this position, it means the next character (which must be a letter) must be at the start of a word. It is called "word break" because you can also use it to mark the end of a word ("rune\b" will find "prune" but not "runes"), and the full technical explanation is "there must be a word character on one side and not one on the other side".
...Copy link to clipboard
Please post screenshot.
hi,
i want to convert text Frame to text Fields for making interactive Pdf so can help me pls..
I'm trying to make GREP expression to find all words that starts with the
capital letter (like Italy, America, Europe, John, etc) and to mark them
with the character style.
I have found one discussion, but the GREP is non-recognisable, \<[A-Z]|[ÈÆ©®Ð]
\<\u\w+
Try this code!!!
var myDoc = app.activeDocument;
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.findWhat = "\\<\\u\\w+";
var found = app.activeDocument.findGrep();
for(i=0; i<found.length; i++)
found.appliedCharacterStyle = "Bold"; // Change your Character style
Prabu
Hi, Prabu
Sorry I'm using mac and I have really no idea whats the code about as I don't know any coding knowledge, thanks anyway
\b\u\w+(\s+\u\w+)+
\u is a shortcut for "any single uppercase character". It matches A-Z, Α-Ω (Greek), and even А-Т (Cyrillic), with or without accents!
\w is a shortcut for "any single word character". A "word" character is anything that can be part of a word, so both uppercase A-Z and lowercase a-z, 0-9, as well as loads of Greek, Cyrillic, Hebrew, Arabic, Japanese, Chinese, and Thai characters. Some that are not "word" are: spaces, punctuation, parentheses, hyphens, and the '&' character.
The '+' ensures 'one or more' word characters must follow the initial uppercase.
\s is a shortcut for "any space character". It will not only match a single space, but also a tab and InDesign's list of more specialized whitespace characters – nonbreaking, third, en, em, figure, and so on.
Again, the '+' allows more than one.
This is followed by another group of 'at least one capital, then anything'.
There are parentheses around the space-then-next-word and a '+' after this, because this entire group – the space plus a possible second word – must occur at least once, and may occur more. This will grab entire sequences of capitalized words at once.
This is what it looks like:
It ignores the first "Hi, I" because there is a comma in between, and also "I" is not followed by (at least) one additional letter. It then correctly picks up the combination "ID CS4", stopping at the first non-word character (the comma), and then it matches the entire phrase "Any Two Or More Words" as one long sequence.
Hi there,
Thanks a lot:) It's very helpful
Hi Jongware,
You forgot Blanche-Neige! 😉
… and here we go: Who are the 'seven dwarfs'?
Personally, surely ´Simplet' (in French)! 😉
