When I select a script from the FrameScript menu, a dialog box should appear where I can select a language to change the text inset flows in my document. This used to work on my machine, and it works on my colleague's machine, but the dialog box no longer pops up for me. But the box must be somewhere because if I press Enter, the script runs as if I selected the first option on the list.
I was on FM 10 when the problem first occurred. I've since installed FM 2017, but there's no change. The box still doesn't pop up.
Help? Thanks in advance. This has stumped both myself and our IT department.
Sometimes FrameMaker will "steal the focus" from FrameScript dialog boxes. Try minimizing the FrameMaker window and you should see your dialog box sitting there waiting for you.
Thanks for replying so quickly. Unfortunately, when this phantom box pops up, I can't click on anything. My only options are to hit Enter to run the script or Esc to get out of it.
You still should be able to hit the minimize button on the main FrameMaker application window. Or, try making the FrameMaker window smaller before you run the script and see if the dialog box appears. If you need further help with this, contact me offlist and I will be glad to take a look at it. rick at frameexpert dot com
