Hello InDesign wizzards,
I am trying to batch process files and need some scripting magic to make it happen. I have a "batch processing" script that would technically convert a bunch of INDD files into PDFs, but I need another step or two inserted in the process. This is what I'm hoping to automate:
INDD File > Open > Place item (in place) called "Setup1" from a library called "Prepress" > Export PDF with "S1" export setting > Append "S1" to the end of the PDF file name
This would need to happen with 3 different page sizes and 4 different "setup" placements. I could run them in batches (i.e. Page size 1 with setup 1, then with setup 2, etc) but of course ideally the script would just run the whole thing for me.
Hopefully this is enough info, thanks in advance!
Ask in the InDesign Scripting forum:
Thank you
