It's become unusable. I have to constantly force quit and re-open. Usually when I reopen the file, it just spins forever until I force quit again. Once in a blue moon it will open the file correctly and I can work with no problems. BUT, if I have to go to a meeting, by the time I get back to my desk, its back to the never ending spinning beach ball. Why is this happening? This exact same file was working flawlessly a couple months ago when I first created it. I'm on the exact same MacBook Pro too with 16 gigs of ram. This is my main function at work and you are killing me.
Are you on Mac 10.12.4 and with Intel GPU?
If yes, try this
You can goto preferences (command+k) and then navigate to GPU performance.
Then turn off the below highlighted preference.
Working then should be fine!
If its not an Intel GPU that you are using, you can start by cleaning your InDesign Cache and preferences Troubleshooting 101: Replace, or "trash" your InDesign preferences
Also, can you mail me the document with which you are facing the issue at amaarora@adobe.com , so I too can reproduce
...Copy link to clipboard
Are you using InDesign version CC 2017.0 or CC 2017.1?
If you are on CC 2017.0 you can try to see if the following two workarounds help you.
1. Upgrade to CC 2017.1 from Creative Cloud
2. Trying out this plugin at the help page Troubleshoot text selection issues
Do let us know if you are on CC 2017.1 or if above steps dont resolve your problem.
-Aman
Version CC 2017.1
Build 12.1.0.56
I'm unable to install the plugin since our corporate IT dept has our machines overly locked down.
The only thing that seems to reliable work is to close everything, restart my MacBook and then open InDesign before any other applications. Then it works OK until the machine goes to sleep. At which point I try force quitting a few times before resorting to the full restart.
If yes, try this
Also, can you mail me the document with which you are facing the issue at amaarora@adobe.com , so I too can reproduce the scenario.
Let us know if this is the case, and if the workaround helped you.
-Aman
After giving it some time, that seems to have helped. It's not crashing or giving me the never ending spinning beach ball anymore.
Fingers crossed that this did the trick.
thanks.
