I'm running Captivate 2017 on Mac OS X 10.12.4.
I want to have a text caption fade in/out using the AlphaFromTo effect.
Here's the standard action I have attached to a button:
Show [object 1]
Apply Effect [object 1] AlphaFromTo [from 0% to 100%]
Hide [object 1]
Apply Effect [object 1] AlphaFromTo [from 100% to 0%]
It is a responsive course, and I have the content in a Fluid Box.
This works when previewing as a .SWF, but not when previewing as a responsive course.
I have not been able to test on an LMS.
I tried to find out if perhaps Alpha is not supported via responsive/HTML5, but couldn't find anything.
Any ideas?
Thank you.
I am a bit puzzled:
I am a bit puzzled:
Thanks for the response.
To clarify, I tested/previewed the fade in/out in both a responsive project and a normal project (.SWF) to see the differences.
Your right, I didn't need to use the Hide action on the object after it faded in. Thanks for pointing that out.
Regarding your second bullet, I didn't think you could use the fade in/out settings in the Timing panel in conjunction with an advanced action triggered by a button click. But I tried it, and got it to work. It's much easier than using the Alpha effects. Thanks for pointing out an easier way to do it!
Fade in/Fade out is a legacy property of an object, but it can be very useful!
