Hi there,
I was just wondering if there's a way to select all spot removal edits and copy and paste them to a different snapshot of the same image? As you might have guessed, I edited the wrong snapshot and would like to save some time if possible! (Everything else about Shapshot 'B' is right, it's only the spot removal I want to add from Snapshot 'A' - so I don't think I want to 'merge' snapshots because the other edits in Snapshot A have been improved in Snapshot B.)
Thanks for your help
Open the two files, select the one you made all the corrections to, then select the one you want the spot healing brushes applied to. Use sync settings and select just spot removal.
Brilliant, thank you! (Since they were snapshots of the same file, I saved one snapshot as a separate .dng so I could open both and sync.)
