I have two people speaking in one audio track of a video. One is asking interview questions, the other answering. I want to completely eliminate the interviewer asking questions -their waveform and just leave the person's voice answering the questions. Is this possible? How? I'm going nuts.
Keyframe the audio volume or just cut the audio out of the track and add a piece of the "silence" in the rest of the track to make the background noise sound natural.
This will only work, of course, if they are not speaking at the same time.
HI Peru Bob,
Thanks for taking the time to answer. Still not sure I explained it proper or, I don’t understand your suggestion.
I’ll use the below image as an example. I have two people speaking in audio 1 and the top wave is the one I want to keep. That person is explaining how to do something. The bottom are just questions and responses. Is it possible to easily cut out the bottom wave? I don’t want to cut out the entire track. I have reduced the audio middle line and they did not help. I don’t know if I can mix out the bottom wave either.
Suggestions?
I see no image.
Make sure you are using a computer and not a phone and are in the forum, not responding to an email:
Windows Vista and later
- Use the Windows Snipping Tool to take a snapshot of the area you want to capture. See Use-Snipping-Tool-to-capture-screen-shots for instructions. Save the result as a JPG or PNG file.
Windows XP and earlier
- Use the Print Screen button on the keyboard to capture the entire desktop, then use a imaging program like MS Paint, Paint.NET, or similar to paste the captured image. Some programs can crop the area you want to show, so you do not need to post the entire desktop. Save the result as a JPG or PNG file.
- More detailed instructions: Take a screenshot on Windows XP
- Alternate screenshot tool: Jing (free download)
Mac OS
- Shift + Command + 4
- Drag the cursor to where you'd like to start one of the corners of the screenshot and press down and drag the mouse over the area you'd like to capture.
- Release your mouse
- The screenshot will be saved on your Desktop
- To post the saved screenshot you need to be in the forum editor; either as a new topic, or as a reply in a topic requesting a screenshot.
- Click on the camera icon in the editor menu to upload the saved image to the current cursor position.
This is just an example of audio 1 where there are two tracks. This is not from my film. Both people are talking at the same time.
I still don't see an image.
Is your audio of each person on its own track?
Please post a screen shot of your timeline in Expert Mode.
No, the audio of both are on the same track and they are at times both speaking together.
In that case, it will be nearly impossible to do in Premiere Elements. Even an experienced audio engineer using expensive professional software will have an extremely difficult time with that.
Thank you for your help.
You're welcome.
