Below we will see the basic techniques for Photo Retouching Beauty which require advanced use of Photoshop, so is not explained how you get a perfect selection, what are the blending modes or whatever because it's taken for granted that you know.
The following techniques are the gateway to the Post Production, but I specify that the same evolve in ways 10 times more complex and include hair, eyelashes, beard, but for obvious reasons these can't be summarized here.
In the end it is important to know that these are the notes in reference to a workshop held by me and these steps require, more than in other cases, the practice with the guidance of a tutor.
For those who have advanced knowledge of Photoshop I hope will find these notes some helpful advice.
Practice is at the root
The most important thing to get quality results is to get away the least possible from the original, the best way to learn is to practice and practice of self portraits.
Which areas of the face you work?
Retouching tools
Working method
1) Maximum Zoom depending on the display, 2) Edit small areas in several steps, 3) Most tools depend on the brush, 4) Use the tools to opacity and lowest flow (15-20%), 5) Working on new levels with method "samples all levels".
TUTORIAL
Cleaning of flaws
First, after stock of the situation (perhaps adding a new blank layer above the subject and with a brush you draw the various parts of the face that need retouching) we start with the "Healing Brush" or the " patch tool " to eliminate defects more apparent.
Eyes: white bulb
1) The white must be worked in the same way, with the fine Healing Brush and neutralizing as much as possible the small red veins.
2) Then we select the eye to create a mask of a new level of curves and with which we lighten the white in a natural way.
3) In the level of curves we will exclude the iris filling with black color the mask in correspondence with its own iris so as to work the white of the bulb separately and independently.
4) Be careful not to whiten too much damaging the credibility of the shot, error by the way of the most common.
Eyes: the iris
The iris can be processed in different ways, but it depends on the eye itself make us decide how to act, generally speaking work with " dodge " on a separate layer (as mentioned above) can lead to good results.
Reflected Light
The secondary reflection is always the exact opposite of the main one and with a brush and white color we paint the reflection (on a new layer), then apply a Gaussian Blur from the Filter menu and change the blending mode to Overlay.
Colors
Ring of the iris
Options
From here the techniques that can be added are varied as select the iris and apply a level of curves, a photographic filter, color consultation or different ways to increase the sharpness and so on ...
** Normally you can emphasize the iris much more, here we keep it as faithful as possible to the original
The Lips
The skin
The most common method for retouching skin in a professional manner is called " Frequencies Separation " and which allows you to work the various imperfections without losing the texture of the skin.
Now we can work on two levels
Completed our retouching we can add extra texture to the skin if necessary
I hope these tips will be useful for those who want to approach the Beauty Retouch.
Gaetano Giordano - ACP Italy
Thanks !
Do you have a video tutorial about this?
I don't think so, but this appears to be his YouTube Channel. I seem to remember a nice compositing video he put a while back, and that I can't see on his channel, so you might be lucky.
We'll see if we can scare him up
Hi El fisgòn,
thanks @Trevor.Dennis yes that's my YouTube Channel, but there's no video tutorial for this article or relative to the beauty retouching yet ... I organize Workshop for photography classes in Italy.
If you have a particular question I can answer here eventually.
