I am using After Effects CS6 and i have created a 3D scene in E3D with 12 Spot lights in a row to light up 6 blocks on a rail, but when i activate the spot lights for the 5th block the lights on 1st block goes off when i do it for 6th then the lights on 2nd block goes off and Vice versa.
Please Help ...Really Urjent
There's nothing wrong. Your graphics hardware apparently simply doesn't support more lights. These are inherent limitations in OpenGL. Only getting a more powerful GPU will solve the issue.
Mylenium
Mylenium
There's a limitation on the number of lights in Element 3D. You seem to have reached it.
E3D supports up to 16 lights, so there's room to spare. It really comes down to the hardware.
Mylenium
Thanks For the Help Sir, I am using I7 6700 Pro & Quadro 7000 GPU.
The card was actually installed in Opti plex 7000 , but i am using it separately so it is Quadro 6000.
That's a fairly old card. As Mylenium says, you'll likely need to upgrade. OR render the two parts of the scene separately.
