Hi I use Acrobat Pro DC, 2015 Release (Classic) Version 2015.006.30060
Architecture: x86_64
Build: 15.6.30060.147031
AGM: 4.30.58
CoolType: 5.14.5
JP2K: 1.2.2.33916
The functionality "Fill & Sign" stopped working, when I choose "Fill & Sign" tool the PDF file is not loaded and I see the blank page. Please advice how to fix it. I fully reinstalled the Acrobat but it did not fix the problem.
The PDF file which you are using is a scanned document? If yes then go to application Preferences, Edit > Preferences
From categories go to 'Page Display' and check the option for 'Show Large Images'
Also are you signed in with your Adobe ID in Acrobat?
If not then sign in with your adobe id.
thank you. both were already done before the post, to no avail.
has anyone found a solution to this problem.... I see a blank white screen as well 😕
I'm having the same experience. Deleting Acrobat and reinstalling seems to be the only fix.
Build: 15.10.20056.167417
AGM: 4.30.61
CoolType: 5.14.5
JP2K: 1.2.2.35592
I was having the same problem on a new MacBook Air. I just updated to El Capitan and the problem seems to have gone away.
Hi anzyny,
Sorry for the inconvenience caused to you. In order to help us find the root cause of the issue, kindly provide us the following details :
For Windows OS
1. Go to Run (Window + R). Type "regedit".
For 64 bit machine go to : HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Adobe\Acrobat Reader\DC\WebResource
For 32 bit machine go to: HKEY_LOCAL_MACHINE\SOFTWARE\Adobe\Acrobat Reader\DC\WebResource
and please verify if "cError" entry has been created or not.
2. Kindly share the snapshot of the contents of these two locations :
For MAC OS
1. Does this also happen with other applications like Send and Track, Send for Signature etc.?
2. When the blank screen appears while opening Fill and Sign, go to Activity Monitor and check whether a process named "RdrCEF"/"AcroCEF" is running or not?
3. Also go to Console application and verify if any crash logs have been generated under "User Diagnostic Reports"/"System Diagnostic Reports". If yes, please share them with us.
3. Go to /Library/Application Support/Adobe/<Reader/Acrobat>/DC/WebResources/Resource0 and capture the snapshot of the contents. Please share the snapshot.
Thanks and Regards,
Sandeep
Same problem for me. I'm working on Mac. When I go to Activity Monitor, I can see that RdrCEf does not respond
Hope this can help.
Hi !
So, here are the informations :
1. Yes, it happens with other applications too (I tried Send and Track, Send for Signature).
2. Just verified and "RdrCEF" does not respond.
3. I verified and found nothing related to Adobe in Diagnostic reports.
4.
Hope this can help
any updates on this one yet. I have same issue as well
Hi sangrover !
FYI, I've just installed the last update. No change 😞
Edit : There was no change the first day but everything seems OK now. I 've no explanation to help. Juste relieved it's working again, since I had a few docs waiting to be signed.
Actually, that was just a temporary relief. Not working again.
Any updates ?
Hello,
I am having the same problem. I have been in three different sessions with chat support and have been unable to find a solution.
Here is what we did:
I still have an open ticket with no resolution.
For MAC OS
none of those method i can use actually and the problem is still here. Do the company have any updated version to fix this issue? For the issue is posted about a year and still not solved that it is very disappointed software bug here. I hope that the issued can be solved as soon as possible.
FYI, Mac Acrobat pro DC user.
I solved the problem. I went back to the previous version of the system
I tried this as well, unfortunately there is no previous version offered.
I am having this problem as well.
It occurs with Fill & Sign, Send & Track, Send for Signature.
I see AcroCEF running in acitivty monitor.
I see no crash logs in Console.
Here is the contents of /Library/Application Support/Adobe/<Reader/Acrobat>/DC/WebResources/Resource0:
Has there been a fix for this yet? The thread is over 2 years old...
Hello,
Same problem here.
I can still sign with the Document Cloud hopefully, but it's not the best option.
Did someone have success fixing it ?
I had the same problem. I un-ticked the "Run this program in compatibility mode for" in Properties - Compatibility tab. Now it's working again.
Hi Kathym,
This fix is only for Windows right?
Mac users don't have this option.
Yes, it's only for Windows sorry.
my prob in windows 32bits also solved using this method, thanks alot
Any Update on this?? Im also having this issue...
