I am making my own certificate in Flash and need the codes to call the score from the Presenter quiz. I tried "getScore", but that doesn't seem to be it. I know in Captivate the code is something like "cp...". What is it for Presenter? Thanks.
I found a workaround that doesn't require much Flash. I redesigned the quiz results page to look like a certificate and added a small Flash to request the person's name.
I will move your question to the Presenter forum, this is the Captivate forum.
Thanks, Liev.
I'm not sure Presenter has the same access to it's action codes. Here is the information for the custom certificate that is most commonly used and it comes from a staff member in Adobe. The list of calls he uses are in this post: Adobe Connect User Community
The calls are for information from the Connect server, rather than Presenter itself.
Thanks. Unfortunately, those did not work. It must be something I'm doing work.
