Hi all,
I've got a source controlled project where one of my clever
developers decided to change the setting within the WebHelp Primary
Layout "Select Output Folder and Start Page" to point to a network
drive, because he thought this would be a good way of publishing
the output directly to the network.
He has been re-educated (!) but the issue I've got now is
that when I've attempted to change this path back to the standard
one, it is no longer tracking the local copy of the project on c:
drives...
What I mean is that if I have the project stored in
"c:\proj_x" and I've set the Output Folder to back to
"c:\proj_x\!SSL!\WebHelp\home.htm"... but my colleague has his
local copy set to "c:\x_proj".. When he does a build, it now
doesn't build to the !SSL! folder within his project, instead it
creates the folder structure as per my settings
"c:\proj_x\!SSL!\etc"
So I'm wondering how I can restore the default behaviour that
we have for our other projects, where RH will automatically build
the Output within the same folder structure of wherever we have it
saved on our local copies?!
I suppose the other question might be around the potential
impact of rolling back the .ssl folder via Source Control.. has
anyone had any issues doing this?
