Windows 10
After Effects CC
Version 14.2.0.198
The blue "Output To" link is clickable, but nothing happens when I do click on it. I have re-installed it, cleared my preferences, and tried the "Clear Settings" option under the Sync Settings menu in the top right.
Do you have two monitors? Is the dialog showing up elsewhere but is behind hidden by something? What about other dialog boxes like "Open" from the File menu, does that show up?
I do have two monitors, but i still can't seem to find it with all other programs minimized. "Open" works fine.
That's definitely odd. Can you post a screen recording of this happening?
Hi, I´m Having this same problem on AE CC 2017. I´m able to use Media Encoder, but the "Output to": link in the render queue died after about 3 weeks of working. Its the same in all projects amd in second output modules. Did not have a previous version of AE installed.
thanks,
Daniel
Ever solve this issue, RyanT? Please let us know so we can assist you further.
Kevin
I suddenly had the same problem last night, with After Effects CC, output to won't be clicked. In CS6 it works.
I have uninstall and reinstall the program numeral times, reset After Effects settings. I can send renders to media encoder, but this is not ideal workflow.
Can you recommend something?
Many thanks,
Elise
hello,
having exactly the same problem in the latest CC version and cant render as is...
any suggestions?
thanks
Hi
Here's how I solve this problem. There should be a folder that you can't reach. I mean sometimes Windows doesn't alllows you to delete a folder you know. You should get rid of that folder first. To specify where the folder is, go to render queue, next to "Output to" link there is a drop down menu, just click random one, and it will allow you to render at your last render directory.
Now that you know where the problem is. There should be a "non deletable folder" in that directory. Find it, erase it. The quick way to do it is, right click the folder, add to archive, select "delete files after archiving". Then simply delete the archived one.
Now the "output to" link should back again.
I followed your directions to find the folder it was defaulting to. The folder was messed up and wouldn't allow itself to be deleted or renamed. I did what you suggested with 7zip. Add to archive - delete after compression. It deleted the folder when it was done and AE immediately allowed the file dialogue box to be opened again once it was gone. Thanks for sharing the solution!
Thankyou very much, it worked for me. and it also solved another problem of deleting the folders which cannot be deleted in windows, may be there are other ways to do that but your way is easy. god bless you for your help
Thank you so much! I’m so glad something finally worked! ❤️
Your a lifesaver 🙂
I am having the same issue but can not find a "non deletable" or corrupted folder.
I'm unable to change the Output Module destination path.
When I click on the "Output To" blue hilighted text nothing happens.
I have deleted prefs, uninstalled and reinstalled After Effects (2021) with no change to the issue.
New projects and new comps just keep defaulting to the same path when I add them to the render que.
This thread is the only conversation I've found relating to this "bug".
What can I do if my folders are not corrupted?
Would appreciate anyone's help with this as I'm in the middle of a big project.
PatRIGT , did you get a final solution ?
Amazing, thank you!
