Hello,
I need some information to certified PDF files with numeric certificate.
We are a french health at work association and we work with medics.
We want to stop the utilisation of paper and we want to replace the manuscrit sign by certificate sign.
i must know Adobe want the utilisation of token with certificate AATL to sign ths PDF files.
So in france the medics have a special card named "Carte CPS" and this card can store a certicate.
Does Adobe Support this solution ? or the token is an obligation ?
I don't know if my question is clear, so we can talk about it.
Thanks a lot,
Regards
Vincent
IT Manager
Hi VincentSISTEL,
Please refer the information provided under FIPS compliance here on this link: Pre-deployment Configuration — Digital Signatures Guide for IT
Check if this answers you query.
Let us know if you need any further information or help.
Meenakshi
Hi VincentSISTEL,
If you need information on the certificate signatures used in Adobe, please go through this help document: About certificate signatures in Adobe Acrobat
Check if this gives the answer to your query.
Let us know if you are referring to something else or need any further information.
Meenakshi
Hi meenakshin,
Thanks for your answer
I found an answer in the website. The certificate can store in smart card or in a token, but an important information is not signified in the website, the level of cryptography is not specified, do you have information about that ?
Thanks a lot
Vincent
Hi VincentSISTEL,
Meenakshi
Thanx for your time and all your answers, that's OK for me i have all the informations.
Vincent
