Hello,
What I have set up is a Multi Machine Render on two computers. After they render out from AE as a Photoshop Image Sequence, I'd like After Effects to auto import the rendered image sequence to a comp to render back out as a QuickTime MOV file (Single Machine render).
My thinking is, I'd like to be able to leave my computer while it renders and not have to come back to set up the second render. Instead come back to have everything completed.
You don't need a script for this. You can do this with Post-Render Actions in the Render Queue:
Basics of rendering and exporting in After Effects CC
To specifically do what you're asking, to render an image sequence and then have that automatically sequence transcoded to a QuickTime file:
I came across something that may work. Has anyone tired this? Is this legit?
Link:
Smart Importer script (for importing image sequences) - AE ENHANCERS
I would recommend against using After Effects for this. If you are just taking an image sequence and making a deliverable out of it (or even a different production format), you should be using the Adobe Media Encoder. You can set up watch folders with it and everything.
Szalam,
I'm getting that AME is faster then AEs Render Engine?
So I should do what Adobe Staff has suggested with AME instead of AEs Render Engine?
Adobe Staff,
Thank you, this way worked!
It's not necessarily faster, but you can work in After Effects on a different project while AME churns away in the background. Or you could have a different machine in your office set to use AME on a watchfolder so your production machine doesn't even have to do that step.
It's really dependent on your workflow.
This is my thinking on this....
If I get AE or AME to Multi-Machine render my projects into a Image Sequence folder, that takes away all the power that goes into rendering all the effects, layers and all together. Now thats done, I get AE to render the already rendered Image Sequence into a QuickTime. Doing that second render would take way faster (On a single machine) as there are no effects or anything like that to be rendered. So the second one should just fly. All around this way should be faster, right?
I didn't know that AME can also Multi-Machine Rendering, is that just as fast as rendering it with AE? Or is it just the connivence of being able to still work on AE while your project is rendering?
AME does not have multi-machine rendering functionality. It does have Watch Folder rendering, but it's designed for use on a single machine, not multiple machines watching the same folder. (I suppose you could try setting multiple machines to watch the same folder, but they won't split up the rendering from a single source like After Effects can. Also, I can't predict what would happen if the the different machines try to render from the same source at the same time. Something bad would probably happen.)
The convenience of AME is that it can render After Effects compositions in the background while you continue to work in After Effects.
*** The downside of nesting your comp for these steps is that if Comp A is already in use by other comps, this method will globally replace all instances of it. You may not want that. To work around this, create a placeholder (File > Import > Placeholder; make sure it's the same dimensions, frame rate, and duration as Comp A), and put that in it's own comp (again, make sure the dimensions, frame rate, and duration are the same). This time, for step 3, instead of opening the Output Module Settings dialog to set the Post-Render Action, twirl open the Output Module settings in the Render Queue; here you'll see the Import & Replace Usage option with a little pickwhip - use the pickwhip to choose the placeholder.
Other things to note about using Post-Render Actions to automatically transcode one output to another:
Also I'm a little confused what Adobe Staff meant when he/she wrote:
"...this method will globally replace all instances of it..."
What I meant is that Post-Render Action: Replace Usage, if set to replace the rendered comp, will replace all instances of that comp in your project. Not just the instance created if you followed the instructions.
Example: your Comp A is used in Comp B and Comp C. By rendering it with Replace Usage, Render A will replace Comp A inside of Comp B and Comp C.
That may or may not be what you desire, which is why I described the alternate method of creating a placeholder.
Thank you for clarifying that for me. I understand what you mean by instances now. Instances are the "layers" in a comp.
Not sure if I'm totally getting it or not, but when you said I wouldn't want the instances to be replace from your first steps and that you have a work around for that. That second idea you added is doing the same thing as the first but replacing the placeholder instance instead of the main comp? I'm just wondering why I wouldn't want to do it the first way instead of the second way? Am I loosing quality or is something happening to the comp that I'm not aware that will effect my output video? I've tried both and they both seems to come out the same way.
Sorry for the confusion and I appreciate all your help!
It's not about quality.
The second method is about flexibility. By creating a placeholder, you don't have to replace the original instances of your comp, you can replace the placeholder which can be a unique item for this purpose.
The first method is probably fine for you. I described the second method because there can be cases where the first method is too limiting.
I understand now. Thank you for all your help!
