im using LR CC 2015.10 and i want to use camera tethering together with my Nikon D750. According to all support documents it shoult work but when i connect my camera (with nikons cable) "camera not found" appears!
Any suggestions?
Wait - after a further try - connecting the cable to another port - it works! thx
Have you tried it without the memory card installed in the camera?
Yes, and i already have deleted the preference file in osx library - no effect
Is Image Capture (Mac OS) or some other software grabbing control of your camera when you connect it, preventing Lightroom's access?
No - i dont think so because when i click to import in library dialogue the camera is available - furthermore i do not use any other image software
Go to Search and open Image Capture. Connect your D750.
Does it appear in the Image Capture window under Devices?
If so, look in the bottom left and expand the arrow and set the action to No Application.
Close Image Capture.
It was already set to NO APPLICATION - i set it to photo and then back to NO APPLICATION - no effect in lightroom.
Then it is time to start troubleshooting components. Alternate Cables and Ports would be a good place to start.
Fix tethered shooting in Lightroom
Thats what i already did - no effect!
Same problem here and switching ports does not works. Tethering works perfectly on Windows 10.
Seems stop working after a Sierra update. One years ago, when i first installed Sierra it works with no problems. Then one of the updates must cause the trouble. I tried everything but D750 with Sierra and LR updated seems impossibile to work. (of course I can see D750 on the import window)
