3D tool in CC2015.5
Engaged ,
May 09, 2017 May 09, 2017
I would like to play around with the 3D tools in Photoshop but all but 2  options are grayed out.  How can I enable all  the options?
Thanks.
428
Adobe
What some menu item can not be use because  a  requirement for  its use is not present.  Photoshop will gray out the menu item because it is currently not usable.
Supply pertinent information for quicker answers
  • The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
  • Adobe product and version number
  • Operating system and version number
  • The full text of any error message(s)
  • What you were doing when the problem occurred
  • Screenshots of the problem
  • Computer hardware, such as CPU; GPU; amount of RAM; etc.
JJMack
Engaged ,
May 10, 2017 May 10, 2017
Yes, but what are the requirements and what is making it unusable?
What option do you want to use each item grayed out may have different requirements for use. There is not a single answer.
JJMack
Engaged ,
May 11, 2017 May 11, 2017
I was trying out a tutorial using text art and it called for the 3D option.
https://design.tutsplus.com/tutorials/3d-stuffed-letters-text-effect--cms-28438
I was not able to do the tutorial because 3D was not available.
Hi
To use 3D you need a graphics card with at least 512GB video ram and your GPU needs to be enabled in preferences. If you meet that requirement - can you post your system info. Just go to help - System Info - Copy then paste it here.
Dave
Engaged ,
Is this the info you asked for?  I don't find an enable/disable for the GPU but I don't know why it wouldn't be enabled.ps3d.png
Engaged ,
I took a quick look at that tutorial.  If you have the proper hardware and your Photoshop preference performance enable Photoshop to use your GPU after you create the text Shape layer.  With that layer targeted when you open Photoshop's 3D menu there should be a few menu items not grayed out. One not grayed out should be "New 3D Extrusion from Selected Path".
JJMack
