It seem that my Mac won't go to sleep if Lightroom CC is started.
In Activity Monitor it is noted that Lightroom prevents sleep.
This is annoying, can it be changed?
Please uncheck "Prevent system sleep during Lr mobile sync" in Preferences>Lighroom mobile.
~Akash
Hi nikonmf,
Please take a look at this article If your Mac doesn't sleep or wake when expected - Apple Support and let us know if that helps.
Akash
The above shows that Lightroom disables sleep, how to change this?
The slider for sleep, is not available on my new iMac27"!
~Akash
Thank you, I guess that was the reason, so problem solved 😉
Have to restart Lightroom 😉
Hi Akash, is there a Photoshop Preferences Setting where I can set this. In opposite to nikonmf I WANT Photoshop to prevent Mac going to sleep - as long Ps has workload to do.
Otherwise when e.g. aligning ≥ 50 layers, Mac goes to sleep, even if 80% of layers to be aligned are left.
My current workaround is
caffeinate -i
in Terminal and I stop it by Ctrl-C if workload of Ps is finished. But it is very inconvenient, it is necessary to do this manually...
You may check by
pmset -g
on terminal, which software prevents Mac going to sleep and which not.
$ pmset -g System-wide power settings: Currently in use: standbydelay 10800 standby 1 womp 1 halfdim 1 hibernatefile /var/vm/sleepimage powernap 1 gpuswitch 2 networkoversleep 0 disksleep 10 sleep 0 (sleep prevented by caffeinate, sharingd) autopoweroffdelay 28800 hibernatemode 3 autopoweroff 1 ttyskeepawake 1 displaysleep 5 tcpkeepalive 1 acwake 0 lidwake 1
In this example it is only caffeinate itself and accidentally the sharing daemon. I ensure you, Photoshop has been running when copy & pasting this on a Focus Stacking of 60 images of a D850.
OK, <pre> does not work correctly in this HTML editor here, so, let's put it a bulky image in:
CU, Roland
PS: The <pre> tag in this editor does not preserve line breaks as defined by w3c. During editing ok. After sending, the line feeds are eliminated. I tried several times.
