Installed and re-installed by IT on the company's Macbook Pro, licensed under the company's site license. The same product installed by the same group on identical Macbook Pros works. When running on my machine I get the message:
An error has occurred.
See the log file
/Users/ppulliam/Documents/Adobe Flash Builder 4.7/.metadata/.log.
When looking in the .log, I see:
!ENTRY org.eclipse.osgi 4 0 2014-12-16 11:30:31.724
!MESSAGE An error occurred while automatically activating bundle com.adobe.flexide.editorcore (105).
!STACK 0
org.osgi.framework.BundleException: Exception in com.adobe.flexide.editorcore.EditorCore.start() of bundle com.adobe.flexide.editorcore.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:734)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
Caused by: java.lang.NoClassDefFoundError: com/adobe/flexbuilder/util/PluginProperties
at com.adobe.flexide.editorcore.EditorCore.initializeOptions(EditorCore.java:212)
Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundException: An error occurred while automatically activating bundle com.adobe.flexbuilder.project (68).
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:122)
Caused by: org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
Caused by: java.lang.UnsatisfiedLinkError: no BridgeTalk in java.library.path
Root exception:
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857)
I've already tried installing version 4.2 of eclipse and using the flash builder plug-in utility to point to my version, as well as a large number of other things.
Pete
Please try the following steps:
Rename the default workspace"Adobe Flash Builder 4.7"( on Mac it's located at /Users/USER_NAME/Documents/Adobe Flash Builder 4.7) and try launching Flash Builder.Even if this doesn't work. Please un-install Flash Builder and use the cleaner tool(from this location http://www.adobe.com/support/contact/cscleanertool.html ) to clean and re-install Flash Builder.
Please let me know if this works.
That didn't work.
However I did figure out that the problem is that the JVM 1.8 doesn't support the Java Native Interface quite right. JVM 1.8 was installed as part of JDK 8 when this machine was set up by IT. Uninstalling the JDK, then installing JDK 7 got things going.
Pete
For anyone who runs into this problem. I am running OSX El Captain you want to remove Java 1.8.
If from the terminal you run:
java -version
and you have something greater than 1.7 Flash builder doesn't run
I happened to have 1.7 on my machine from before so simply navigating to:
cd /Library/Java/JavaVirtualMachines
and
sudo rm -rf jdk1.8.0_51.jdk/
worked for me
This page helped
非常非常感谢你
Here is the solution:
Flash Builder Preimum 4.7 crashes on mac
FB will not run on java sdk 1.8.x
Scroll to the bottom of this link, and the solution is there.
lrlarson
