So, I have multiple file importers installed for opening EXR files (EXR-IO, ArionFX, default one). Can I choose which one to use?
For instance, uninstalling EXR-IO did not actually disable the importer, I had to manually search for some plug-in files and delete them, and now I'm stuck with the demo version of ArionFX, which I still want to experiment with, just not at this time as I need to edit some files without the getting the watermark. The default EXR importer would be fine.
Hi vreima,
I believe this plugin would be helpful for what you're looking Install and use the OpenEXR Alpha plug-in in Photoshop CS5 Extended
Akash
Hi vreima,
Akash
