I've never had this issue in 5 years and I'm perplexed.
So I edited a simple animation in After Effects using an EPS vector file. In After Effects, it looks perfect. "Continuously Rasterize" is on. I exported it to "Lossless with Alpha" which still looks 100% smooth, exactly like AE. Then I put it at the end of my video in Premiere and export to H.264 > YouTube 1080 preset and just the logo portion of the animation becomes blurry. Not the text. Here are two samples. The top one is a screenshot from Premiere looking super crisp. The second screenshot is after exporting to H.264 > YouTube 1080 preset. As you can see in the 2nd image, the Sonic logo is blurred slightly while the text and Instagram logo remain super crisp.
Things I've tried:
I know the difference isn't that noticeable but it's driving me bonkers.
It's the red in the logo combined with the black background.
H.264 does a crummy job with reds anyways, but it only gets worse at an edge with a sharply-defined edge and high contrast.... and you have both of those conditions.
But all things considered, it doesn't look too bad. It's just not razor-sharp.
What Dave said. Bright reds are the worst kind of color for any MPEG-based compression and slumping it on a black background simply causes an extreme pedestal in contrast, bringing the algorithms to their limits. You can see that on your color scopes (if you care to use some). Unless you change the design, this won't improve further.
Mylenium
