Locked
Can't package to IPA with AIR25!
Apr 11, 2017 Apr 11, 2017
Instruction does not dominate all uses!
  %doubleToAtom = call i64 @llDoubleToAtom(%"avmplus::AvmCore"* %core, double 2.000000e-01)
  call void @_ZN8halfmoon5Stubs14do_abc_setpropEPN7avmplus11MethodFrameEPKNS1_9MultinameExx(%"avmplus::MethodFrame"* nonnull %methodFrame, %"avmplus::Multiname"* %"MN: scaleY", i64 %MC83, i64 %doubleToAtom)
  call void @_ZN8halfmoon5Stubs14do_abc_setpropEPN7avmplus11MethodFrameEPKNS1_9MultinameExx(%"avmplus::MethodFrame"* nonnull %methodFrame, %"avmplus::Multiname"* %"MN: scaleX", i64 %MC83, i64 %doubleToAtom)
LLVM ERROR: Broken function found, compilation aborted!
  %doubleToAtom = call i32 @llDoubleToAtom(%"avmplus::AvmCore"* %core, double 2.000000e-01)
  call void @_ZN8halfmoon5Stubs14do_abc_setpropEPN7avmplus11MethodFrameEPKNS1_9MultinameEii(%"avmplus::MethodFrame"* nonnull %methodFrame, %"avmplus::Multiname"* %"MN: scaleY", i32 %MC83, i32 %doubleToAtom)
  call void @_ZN8halfmoon5Stubs14do_abc_setpropEPN7avmplus11MethodFrameEPKNS1_9MultinameEii(%"avmplus::MethodFrame"* nonnull %methodFrame, %"avmplus::Multiname"* %"MN: scaleX", i32 %MC83, i32 %doubleToAtom)
Compilation failed while executing : compile-abc
What 's the hell??
Air beta
1.7K
Adobe Employee ,
Thanks for reporting the issue, a couple of questions to help us investigate it.
Can you please tell us the exact version of AIR SDK you're using?
Would it be possible for you to share the swf/xml (privately) which is exhibiting this issue?
We would also need to know the way you're packaging your application.
-Thanks
Pahup | Adobe AIR Engineering
I use FlashBuilder4.7 with AIR25.0.0.143.
May I have your Email Address for sending the swf file?
Adobe Employee ,
Thanks for your reply. Please feel free to send me a private message (hover on my name link, there you'll see a button to send message) on forums.
-Pahup | Adobe AIR Engineering
Adobe Employee ,
Thanks for providing the swf. To look further into this can you please let us know if you are able to package the same swf with older version of AIR SDK?
Also, please share the source code of the swf, you can directly send me at krguptaATadobeDOTcom.
Krati | Adobe AIR Engineering
Adobe Employee ,
May 11, 2017 May 11, 2017
Can you please share a smaller application which reproduces this issue, this would help us in investigating this issue sooner.
I see that you have a class that includes Japanese characters in it. Not sure how well the compiler gets on with those.
Was there a reason to name a class as Line刀光? From the name I wonder if it's a light saber that you're drawing.
Adobe Employee ,
Jan 31, 2018 Jan 31, 2018
We observed in the shared project that if instead of defining the variables of any type you declare it to be a type of MovieClip, the project packages successfully without any error. This change will be made in  com.MyClass.Effect.MyEffect_WindowAppear_Scale. The variables mc and MC need to be set of type MovieClip.
Krati
Feb 04, 2018 Feb 04, 2018
Although a bit late, but still thanks very much.
BTW,Is there a new RoadMap for 2018?
