      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
Keyboard Shortcut for Non existing command in Win en_US Shortcuts.txt
May 11, 2017 May 11, 2017
I'm looking for what's missing in the Help docs on this topic.
Where can I find a list of the valid names of all the menu items, as they would need to be referenced in the Adobe After Effects 14.2 Win en_US Shortcuts.txt.
Or, is is possible to map shortcuts to items that do not already exist in  Adobe After Effects 14.2 Win en_US Shortcuts.txt.
is editable, and this works well UNTIL...
For instance:
I want to map a shortcut to a menu item that does not already exist in this file.
What would be the command to map >Edit >Preferences >Video Preview
for comparison
>Edit >Preferences >General   is "PrefsGeneral" = "(Ctrl+Alt+;)"
from trial and error i've learned
>Edit >Preferences >Video Preview will not work with
"PrefsVideoPreview" = "(Ctrl+Alt+Shift+P)"
nor  "PrefsVideo" = "(Ctrl+Alt+Shift+P)"
nor  "PrefsPreview" = "(Ctrl+Alt+Shift+P)"
nor  "Video" = "(Ctrl+Alt+Shift+P)"
nor   "Preview" = "(Ctrl+Alt+Shift+P)"
nor   "VideoPreview" = "(Ctrl+Alt+Shift+P)"
(Note: I am well aware of the Numpad Slash shortcut to disable and enable this function. This is not a good solution for my problem. In my case, Monitor sharing for the group preview monitor in the center of our studio causes the prefered preview monitor to change when I switch away from it for someone else to use. So I often have to set this back to the desired monitor when it varies.)
(Also note: I am aware that there was a pre-existing mapping for (Ctrl+Alt+Shift+P) and I have disabled that. It is not the reason this does not work.)
Thanks in advance for any lists, or insight on this.
Henry
843
LEGEND , May 19, 2017 May 19, 2017
Oooh, a Preferences selection.  That's going to be tough.  Very, VERY few people need a keyboard shortcut for something like that.  Preferences are something you usually set and forget.  They're just not accessed very often.
This may be something you would have to do by a script, which isn't very efficient.  But people smarter than I am will have to figure it out.
I take it that you find the controls in the Preview pane to be inadequate.  It would be nice to know what you want to accomplish.
Dave! You're legend on these forums! Thanks for your attention.
What I need is a keyboard shortcut in AE that opens this panel, directly. Can it be done?
Right now the best I can do is a macro on my Nostromo.
Thanks in advance,
Henry
Thanks a lot Dave. See you around.
There's a Blackmagic Design product that handles routing the video preview from the monitor at the workstation to a group monitor via the Blackmagic Design video routing software, but I'm forgetting the product name.  I'll see if I can track the name down.  I used at the Advanced Digital Services department at Directv, but that no longer exists since the merger with AT&T.  Of course, it also means having the BmD hardware as well.
-Warren
Thanks for the help Warren. This solution would be a little off the mark for what I want, but I do appreciate your help. Thanks.
