Typing no font just an underline
The key to the right of the top row of numbers, just right of the zero key, using the shift key, types an underscore as characters.
Are you asking how to do this, or is this happening when you didn't want it to?
Hi Halena,
do you say, that you are typing something and you can only see an underline growing while typing and no actual character?
If yes, then the fill color of the text is "None" wheras a different color is applied to the underline.
Or: The fill color of the text is white on a white background perhaps.
Select some text and do the keyboard shortcut for the Story Editor window. cmd+y on the Mac.
Now you should see the actual contents of what you typed. Even if it is not visible against the background.
Uwe
Thank you...
I knew it had to be something so simple and something I caused. Thank you so much, Uwe!!!!
It is fixed But,Thanks, Michael!!!
Thanks for you help, It was that I was writing in white.
