Server Side Form Validation Page Shows HTML
May 12, 2017 May 12, 2017
I saw a post about this a few years ago, but never an answer.
We have some very old forms that use the hidden field type of server side validation to check required fields (_required).  The same forms on ColdFusion 10 return a correctly formatted validation error page.  The form under CF11 returns a page that shows the html tags.
The form contains hidden fields like this: <input type="hidden" name="From_required" value="Name of person submitting request is required.">
When a form is submitted with an empty field the page displayed looks like this:
Form entries are incomplete or invalid.
   <ul><li>Name of person submitting request is required. </li></ul> Go <a href="javascript:history.back()">back</a> and correct the problem.
I know using this type of validation isn't good, but we need to get them over to CF11 as is for now.  I tried changing the form to a cfform, but got the same results.  I also changed the _required to _cfformrequired, but no difference.
Any ideas what may be causing this?  Any suggestions appreciated.  Thanks.
454
May 15, 2017 May 15, 2017
It is a bug. Please report it.
In the meantime you could quickly, and simply, set up a workaround. Remove the _required, then use validation by means of jQuery.
You may use this jQuery validation example​:
<form method="post" name="userForm">
  First name:<br>
  <input type="text" name="firstname">
  <br>
  Last name:<br>
  <input type="text" name="lastname" >
  <br>
E-mail:<br>
  <input type="text" name="email">
  <br><br>
  <input name="sbmt" type="submit" value="Submit">
</form>
<script src="https://cdn.jsdelivr.net/jquery/1.12.4/jquery.min.js"></script>
<script src="https://cdn.jsdelivr.net/jquery.validation/1.16.0/jquery.validate.min.js"></script>
<script type="text/javascript" >
// Wait for the DOM to be ready
$(function() {
  // Initialize form validation on the registration form.
  // It has the name attribute "registration"
  $("form[name='userForm']").validate({
    // Specify validation rules
    rules: {
      // The key name on the left side is the name attribute
      // of an input field. Validation rules are defined
      // on the right side
      firstname: "required",
      lastname: "required",
      email: {
        required: true,
        // Specify that email should be validated
        // by the built-in "email" rule
        email: true
    // Specify validation error messages
    messages: {
      firstname: "Please enter your firstname",
      lastname: "Please enter your lastname",
      email: "Please enter a valid email address"
    // Make sure the form is submitted to the destination defined
    // in the "action" attribute of the form when valid
    submitHandler: function(form) {
      form.submit();
</script>
May 16, 2017 May 16, 2017
You're using <cfform tags?
Chuck
Documentation
