Trim a clip that has a transition
May 12, 2017 May 12, 2017
I am using Premiere Elements 15.  I am trying to trim a clip that has a transition between it and another clip.  I want to trim it at the point where it is next to the other clip, but I can't seem to do that.  Whenver I grab the Trim from End icon and move it, it actually trims the transition.  The only way I can find to trim the clip itself is to delete the transition, trim the clip, then re-insert the transition.  Is there a way to do this without having to delete the transition?
Any help would be greatly appreciated!
317
Community Expert , May 15, 2017 May 15, 2017
Make sure you have the track expanded vertical.
If you are trimming the transition, it's because you have the transition selected.
Click to select the clip you want to trim instead. Then you can trim it separate from the transition, which will remain in place.
Yes, I know I have to have the clip selected.  I click the clip, not the transition, then when I grab the Trim from End icon, apparently the transition gets selected.   So when I drag it, the transition gets trimmed.  I have made sure over and over that I am clicking in the middle of the clip so that I am not selecting the transition, but as soon as I try to drag the Trim from End icon, the transition gets selected.  I have tried it over and over and over.
That did the trick!  I knew it was  probably something really simple… and it was! Thank you so much!
