Hi everybody,
every now and then I look into Cineware and check for improvements. It's a great frustration to see I can't get an AE camera rig to work in Cinema 4d.
I create a composition and a camera and a 3d solid. I put keyframes in the camera point of interest, position, orientation and rotation. Export using Maxon Cineware 3d exporter from the file menu. Import that file in AE again, put it in the composition and set the cineware camera to 'Centered comp camera'. This way everything works perfectly I have the cinema 4d scene working in after effect. Same camera movement! And if I open the cinema 4d file I created with Cinema 4d, everything is perfect! All good.
Start of animation in Cineware:
End of animation with Cineware:
End of animation in Cinema 4D
Here's the problem:
if I create a scene in AE with a camera linked to a 3d NULL object, something goes wrong. Everything in AE works fine but if I open the cinema 4d file with Cinema 4d the camera goes nuts.
Start in cineware:
End in Cineware
End in Cinema 4d:
It happens both with 'orient towards point of interest' and 'off' in AE auto-orientation settings.
Is it what normally happens or is it something wrong with my software/workflow/settings?
Hi Zulkifar,
I did hear back from engineering. Here's the response, "It’s a known issue and one of our highest priority bugs to fix. When animating the same property or dimension on a parent/child, the child’s transforms are ignored when exporting to Cinema 4D."
Sorry for the frustration. Feel free to file this bug here.
Kevin
Up.
Is it happening just to me?
Hi Zulkifar,
Did you solve this issue yet? We've had an update since this post was written, have you had better success with that? Please let us know.
Kevin
Hi Zulkifar,
Kevin
Hi Kevin, I really appreciate your reply.
I'll be waiting for the bug to be fixed.
Thanks again!
Sure. Sorry for the annoying bug.
Take care,
Kevin
Hi there,
I seem to be experiencing this same issue, was this bug ever resolved? Using a simple camera rig and AE with a Cineware scene seems unusable
Steve
Hi this is happenign to me as well. Has this issue been resolved by Adobe?
