I am trying to figure out how to make the little green circle a "globe" as it circles the larger one. I got it to circle it perfectly but when it circles, it is a "1D" disk not a globe. Below is how I have everything set up - the null is attached to the MOON (the green one) and then Y orient makes the green one go around the blue one.
Any help is appreciated. Thanks.
Create an expression on the y rotation of the moon by alt-clicking on the y rotation stopwatch and then pick-whipping it to the nulls y rotation. Then edit the expression by putting the whole expression in parenthesis and multiply it by -1. i.e. (EXPRESSION) * -1. That should keep the moon always facing front (as long it's anchor point is centered). Does that make sense?
Oh boy I think I know why that expression method is not working now. When I drew the small circle for some odd reason that little cross hair thing (I think that's the anchor point?) that's with it is NOT in the center of the circle. I have no idea why because I drew it exactly the same way as the large one and the anchor is inside of that one.
Can you tell me why that may happen? Can you tell me how to get the anchor back into the middle of the little green circle?
Ctrl+Alt+Home to center the anchor point or right click->transform>center anchor point in layer content
That's great thank you Roei and Gutter Fish.
