Is it possible to create a script that adds a prefix to the selected layer?
If the selected layer is named "FillLayer"
and the prefix is named TDD_
the result would be:
TDD_FillLayer
I'm not looking for a pop up dialogue window. But just the script by which i can change the prefix name there.
Thanks for any help!
Jeff
#target photoshop;
if(documents.length){
var doc = activeDocument;
var prefix = "TDD_";
doc.activeLayer.name = prefix + doc.activeLayer.name;
Yes it is possible to rename a layer and you can get a layers by name. I is also possible to have layers with duplicate layers names. If the are duplicate layer names I do not know which layer would be gotten by layer getByName.
app.activeDocument.activeLayer = app.activeDocument.artLayers.getByName("Name");
Any chance of sharing this wisdom?
..assuming its not complicated to create.
#target photoshop;
a little bit more precise
#target photoshop;
if ( documents.length ) {
var lay = doc.artLayers.getByName ("Ebene 1");
doc.activeLayer = lay;
if ( doc.activeLayer.name.slice(0,4) != prefix ) {
Jive is buggy since weeks.
No edit is possible (and other things).
The line
is not required.
Thanks, pixxxel schubser
Was getting an error with it...
SuperMerlins code fits my needs perfectly.
But thank you very much for the reply!
Jeff
Sure. You didn't have a layer with name "Ebene 1".
SuperMerlins code only works with the active layer. And if this layer already have the prefix - his code will nevertheless add the prefix again (and again, and again) if the script runs again.
Is there also a easy way to make this apply to all selected layers? Not just the current layer. I've been trying to search around, but have come up empty.
Cheers!
Please read carefully all threads.
