Hi, I've been trying to find a way to export projects files for my colleagues in the university because they told me that they can't open the projects files I send them with Adobe Flash Pro CS3, I looked for some Backwards Compatibility tips but none is working, is there any solution that helps with this?
Best Regards
It was CS5.5 when things changed. That version was made future proof, and you can still open Animate 2017 FLAs in CS5.5. If you have a CC subscription you can install CS6, that too can open Animate 2017 files, and it still is able to make AS2 FLAs.
If you really needed to get a file back to CS3 you would need to find a copy of CS5.5, open the FLA and Save As CS4. You would then need a copy of CS4 to do the Save As to CS3.
Thank you Colin, I will try that now
Colin Holgate
Thank you Colin once again for your solution, this was kind of boring process but it worked for me.
Glad you managed to find CS5.5 and CS4!
Also maybe get your colleagues to stop using a decade-old version of Flash.
Lol, they are still using windows 7 what upgrade are you talking about hahahah
Half the world is still using Windows 7.
