Hi.
my script need to close and open several times for updating parameters.(win.close(); eval(myScriptPath) )
when the script closing, allocated space for memory will not be empty and when open again memory allocated increase.
what is solution for getting empty memory after closing it?
thanks for answering ...
You can't control memory handling with scripts. AE handles this all by itself since the scripts obviously only are reflections of internal commands. At best you could append a "purge" command after your script, but that would also affect the undo queue and some other things, which may not be what you want.
Mylenium
Mylenium
