Hello
I cannot authorize a book bought in Wiley online. ADE user/password are correct. I can read the book if I do not authorize within Adobe but only in a single device.
You get which error message if you try to authorize ade?
"You can only authorize this device with an Adobe ID not previously used to authorize another device…." (see attachment)
Not tried to authorize in any other device...
Windows:
Close all applications.
Press WINDOWS + R.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
Remove the Adept Folder.
In the Confirm Key Delete dialog, click OK.
Close the Registry Editor.
Open Adobe Digital Editions and reauthorize..
Macintosh:
quit Adobe Digital Editions.
Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
I followed your steps and now I cannot even read the document in the only device where I could read it.
Alternatives?
You must ask his reseller for a new file which are linked right with your adobe id.
E_AUTH_NOT_READY
Okay, you've approved it. Now what? I am trying to authorize my computer after downloading Digital Editions 3.0 so that I can purchase - and ready - books in the new ePub3 format. That error message is what I've received for the past 4 days! I've not done this before so am not sure what the protocol is now. Do I wait for someone to get back to me with a solution? Should I try the solution you gave to Roberto in an earlier message? If it doesn't work, how hard is it to put things back the way they were?
