2
Photoshop CC OpenCL option greyed out - still not resolved
May 14, 2017 May 14, 2017
I am unable to use features in Photoshop CC 2017 that require OpenCL to be available.  The option to use this is greyed out.
I am advised by NVidia that my GU (GeForce GT705 (OEM)) is compatible with OpenCL 1.1.  I have the latest driver installed.
My query is - assuming my card is OK, why is this option unavailable to me in Photoshop?
Other users seem to have the same issue, but I have yet to see a reply that resolves this problem
24.8K
Adobe
Do you have 'use Nvidia' selected for Photoshop.exe and Sniffer.exe in the Nvidia Control Panel/ Manage 3D settings/Program Settings?
Reference and moore answers:
Why OpenCL is grayed out in supported and updated graphics card?
May 15, 2017 May 15, 2017
Thank you for your reply ... I do not see that option in the Nvidia Control Panel/ Manage 3D settings/Program Settings when I open Nvidia control panel.  I have Option1 - Select a program to customize, Option 2 - Specify the program settings.
Is this more helpful?
Step 1: Right click on your desktop, and select "NVIDIA Control Panel"
Step 2: Click "Manage 3D Settings."
Step 3: Click the "Program Settings" tab, using option 1 "Select a program to customize" and find the game.
Step 4: Under option 2 "Select the preferred graphics proccessor for this program:" you want to select "High-performance NVIDIA processor.
Step 5: Click apply, it may take 30 seconds or so for the settings to apply. I think 3D settings is the menu option.
Check this link for other screen shots. https://www.google.com/search?q=Nvidia+Option1+-+Select+a+program+to+customize&safe=off&source=lnms&...
Thanks again, but as mentioned previously, I do not see the same option 2 as your screen shot.  My option 2 is as option 3 in your example - see below:Capture.JPG
Look at the Global  settings tab and try this:
1)Right click on desktop and choose "NVIDIA Control Settings"
2)Look at left panel,under
3D Settings --> Manage 3D settings
now you have 2 tabs GLOBAL SETTINGS and PROGRAM SETTINGS.
Under GLOBAL SETTINGS tab under "Preferred graphics processor" choose "High Performance NVIDIA processor". Don't change any other details on that tab.
Now,under PROGRAM SETTINGS tab
click the button ADD which will ask you to browse the program you want.
Add sniffer.exe and Photoshop.exe (from C:\Program Files\Adobe\Adobe Photoshop CC 2015).
choose the ".exe" file and click OK,the under "select the preferred graphics processor for this program" choose "High performance NVIDIA processor".
Click OK(if there is any) to save the changes and you're done.
Next time when you open Photoshop it will run by NVIDIA card.
I do not have that option ...under the Global Settings tab there are simply Features and Settings.  See my previous screen shot which is the same for both the Global tab and the Program Settings tab.  I cant find any way to update the Control Panel program, so assume I have the latest version.  In Photoshop, I do have the option to select a graphics processor (which I have done) but the OpenCL option remains greyed out.  In Device manager, I only see one entry (my Nvidia card) under Display Adapters.Capture02.JPG
Ok, so that idea assumed  two GPUs, the lower performance onboard and the high preformance Nvidia.
As a fellow user and forum volunteer I can only go so far.  Customer Care contact-bumper might be able to help you sort it out, and Nvidia might, but apparently the Sniffer is missing OpenCL.
OpenCL is for the Oil Paint filter and CC 2014 had the previous version that didn't need it. As a CC member you can install that as a workaround.
Follow the screenshots under Install Previous versions. You will be able to keep and use CC 2017.
Gene
May 16, 2017 May 16, 2017
Thanks again for all your help - much appreciated.  I'll follow the link you sent to see if this can be elevated.  This does appear to be a common problem amongst many users that is simply not being addressed.  Even a hint as to whether it is the card / driver supplier, Adobe - or me would be a start!
Unless I am mistaken, the only option available via the contact-bumper link above is to post (again) on a forum!  Seem to be going round in circles.
I have not been there in a while, but it seems they really are directing even CC customers to the Support forums.
I did fetch a document in regard to Graphics cards which may cover a lot of what I forgot.
Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
If no good, DM them on Twitter, Adobe Customer Care (@AdobeCare) | Twitter
If still no good, I'll see if I can get ahold of a Adobe Staff member.
Gene
This is from myPhotoshop "System info" option:
clgpu[0].CLPlatformVersion="1.2"
clgpu[0].CLDeviceVersion="1.1 CUDA"
I'm not sure what 'PlatformVersion" means, but if it is the minimum required (1.2) and my "DeviceVersion" is lower (1.1), then that might explain it?
The Adobe web site states that Photoshop requires a minimum of OpenCL 1.1 though ... so this might not follow.  Just a thought.
Paste the entire contents from Help > System Info and let me see what I can find.
May 17, 2017 May 17, 2017
Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
Number of Launches: 1013
Version: 10 or greater
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 4
Logical processor count: 8
Processor speed: 3592 MHz
Built-in memory: 16335 MB
Free memory: 7962 MB
Memory available to Photoshop: 14480 MB
Memory used by Photoshop: 60 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Disabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=0
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="NVIDIA GeForce GT 705"
glgpu[0].GLVendor="NVIDIA Corporation"
glgpu[0].GLVendorID=4318
glgpu[0].GLDriverVersion="22.21.13.8205"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="GeForce GT 705/PCIe/SSE2"
glgpu[0].GLRendererID=4172
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvddi.inf_amd64_ceb004fb0727e620\nvldumd.dll"
glgpu[0].GLDriverDate="20170501000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[65536]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
clgpu[0].IsIntegratedCLGPU=0
clgpu[0].CLMemoryMB=2048
clgpu[0].CLName="GeForce GT 705"
clgpu[0].CLVendor="NVIDIA Corporation"
clgpu[0].CLVendorID=4318
clgpu[0].CLDriverVersion="382.05"
clgpu[0].CLBandwidth=1.0935e+10
clgpu[0].CLCompute=47.957
License Type: Subscription
Serial number: 96040236162151751087
GUIDBucket:
  bucket: 209
  test: DocumentPanel
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\Keith\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 1.80T, 1.15T free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
   AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
   AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
   AdobeOwl.dll   Adobe Owl   5.2.11
   AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
   AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
   AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
   AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
   AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
   AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
   adobe_caps.dll   Adobe CAPS   10,0,0,6
   AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
   ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
   AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
   amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
   ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
   AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
   AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
   Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
   BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
   boost_date_time.dll   photoshopdva   10.0.0
   boost_signals.dll   photoshopdva   10.0.0
   boost_system.dll   photoshopdva   10.0.0
   boost_threads.dll   photoshopdva   10.0.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
   CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
   dnssd.dll   Bonjour   3,0,0,2
   dvaaudiodevice.dll   photoshopdva   10.0.0
   dvacore.dll   photoshopdva   10.0.0
   dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
   dvamarshal.dll   photoshopdva   10.0.0
   dvamediatypes.dll   photoshopdva   10.0.0
   dvametadata.dll   photoshopdva   10.0.0
   dvametadataapi.dll   photoshopdva   10.0.0
   dvametadataui.dll   photoshopdva   10.0.0
   dvaplayer.dll   photoshopdva   10.0.0
   dvatransport.dll   photoshopdva   10.0.0
   dvaui.dll   photoshopdva   10.0.0
   dvaunittesting.dll   photoshopdva   10.0.0
   dynamiclink.dll   photoshopdva   10.0.0
   ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
   icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
   igestep30.dll   IGES Reader   9.3.0.113
   imslib.dll   IMSLib DLL   10.0.0.11
   JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   LogSession.dll   LogSession   7.4.1.60.45263
   mediacoreif.dll   photoshopdva   10.0.0
   MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
   Plugin.dll   Adobe Photoshop CC 2017   18.1.1
   PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
   PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
   PSArt.dll   Adobe Photoshop CC 2017   18.1.1
   PSViews.dll   Adobe Photoshop CC 2017   18.1.1
   SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
   SVGRE.dll   SVGRE   79.579975   79.579975
   svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
   tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
   VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
   VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
   WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
   Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
   Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
   Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
   Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
   BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Camera Raw 9.10 - from the file “Camera Raw.8bi”
   Camera Raw Filter 9.10 - from the file “Camera Raw.8bi”
   Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
   Chrome 18.1.1 - from the file “Filter Gallery.8bf”
   Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
   Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
   Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
   CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
   Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
   Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
   Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
   Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Cutout 18.1.1 - from the file “Filter Gallery.8bf”
   Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
   De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Dicom 18.1.1 - from the file “Dicom.8bi”
   Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
   Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
   Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
   Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
   Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
   Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
   FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
   Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
   Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
   Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Fresco 18.1.1 - from the file “Filter Gallery.8bf”
   Glass 18.1.1 - from the file “Filter Gallery.8bf”
   Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
   Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
   Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
   HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
   HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
   IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
   IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
   JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
   Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
   Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
   Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Liquify 18.1.1 - from the file “Liquify.8bf”
   Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
   Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
   Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
   Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
   Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
   Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
   Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
   NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
   Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
   ON1 Effects Free 10 10.5.1 - from the file “PerfectEffects.8li”
   ON1 Effects Free 10 Filter 10.5.1 - from the file “PerfectEffects.8li”
   OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
   Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
   Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
   Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
   PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
   Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
   Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
   Photoshop Touch 14.0 - from the file “PSDX.8bi”
   Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
   Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
   Plaster 18.1.1 - from the file “Filter Gallery.8bf”
   Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
   PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
   Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
   PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
   Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
   Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
   Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
   Save for Web 18.1.1 - from the file “Save for Web.8be”
   ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
   Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
   Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
   Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
   Spaces 18.1.1 - from the file “Spaces.8li”
   Spatter 18.1.1 - from the file “Filter Gallery.8bf”
   Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Sponge 18.1.1 - from the file “Filter Gallery.8bf”
   Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
   Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
   Stamp 18.1.1 - from the file “Filter Gallery.8bf”
   Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
   Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
   Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
   Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
   U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
   Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
   Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
   Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
   Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
   Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
   WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
   Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
   Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
   ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins:
   Analog Efex Pro 2 2.0.12.12 - from the file “C:\Program Files\Google\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”
   BackgroundFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”
   Color Efex Pro 4 4.3.24.12 - from the file “C:\Program Files\Google\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”
   Dfine 2 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”
   FineStructuresFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”
   HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
   HotPixelsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”
   Merge to HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
   Nik Collection Selective Tool 2.1.28 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\Google\Selective Tool\SelectivePalette.8li”
   ShadowsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”
   Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”
   Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”
   Silver Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”
   SkinFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”
   SkyFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”
   StrongNoiseFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”
   Viveza 2 2.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
   com.adobe.inapp.purchase  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
   Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   Libraries  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
   New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
   Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
   com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
   ON1  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\onOne\index.html”
   Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
   Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
   Device Preview  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
   com.adobe.preview.loader  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
Ok, I'm going to see if a Adobe Staff can get in touch with you.
Standby.
Gene
I notice you have some Nik plugins.
Try starting photoshop with the third party plug-ins disabled and see if OpenCL becomes available.
Hold down the Shift key and launch Photoshop. A dialog appears during launch that reads “Skip loading optional and third-party plug-ins?”
Skip loading dialog box
Thanks for the suggestion - no difference, I'm afraid ...
Adobe Employee ,
May 18, 2017 May 18, 2017
Hi Keith,
Have you tried different variants of the GPU driver available for that card?
Short of all that you and Gene have tried so far that would be my main suggestion.
If you've tried current GPU driver and perhaps a couple variants of older editions, there are still chances that some of the GL/OpenCL functionality will be unavailable in Photoshop, even if the card meets minimum requirements.
So I'd give different drivers a go and see how that goes. Otherwise it's possible the OCL support may not be there with this GPU.
Regards
PG
p.s. Thanks Gene for helping out!
May 19, 2017 May 19, 2017
Hi PG
Thanks for assisting (and of course to Gene for his ongoing help and persistence).
I have tried the previous version of the GPU Driver (no different re OpenCL capabilities) and will look to see if others are available.
I haven’t mentioned this previously, but I have a similar issue with Photoshop on a Dell Windows 10 laptop – this time with an AMD Radeon card + latest driver.  I have tried various driver versions with this GPU – all exhibiting the same symptoms.
I don’t understand your comment “there are still chances that some of the GL/OpenCL functionality will be unavailable in Photoshop, even if the card meets minimum requirements”.  The Adobe website clearly states that the cards I have are “tested”.  There is little point claiming this if they don’t actually work … so my assumption is that “tested” = “working”.
Hence, to claim they work, yet there is a chance some functionality is missing, seems rather misleading to me.
Regards
Keith
May 23, 2017 May 23, 2017
Update ... a new driver has been released (22 May) for my GPU, which I have installed.
OpenCL is still greyed out.
If I open an image and select Oil Paint (so far NOT greyed out), I still get the error (in Photoshop CC) that my driver needs updating.
If I convert the image to a Smart Object, I do NOT get the error, but none of the associated functionality works - eg changing any or all of the settings has no effect on the image.
Keith
Edit:  PS  Every time I launch Photoshop since updating the driver, I get Account Control asking if it is OK for Photoshop to make changes to my device ...
Adobe Employee ,
Hi Keith,
Regarding the Account Control: If you get properties on the Photoshop icon you're using to Launch Photoshop, and goto the Compatibility tab -- Do you have Run as Administrator checked? That'll cause the Account Control to ding at you every launch.
Regards
Pete
May 24, 2017 May 24, 2017
Hi Pete
Thanks again for your continued help, but … I had “Run as Administrator” set in Properties | Shortcut  | Advanced, but this option was unchecked in the Compatibility tab.  So, I set it – no change in behaviour.  I have also set it in the main options when you right click the Photoshop desktop icon, where it now adds a shield against the icon.  Still invokes Account Control, no matter how I try to open the program.
Regards
Keith
PS  I have since REMOVED "Run as Administrator" (to lose the yellow / blue shield it added to the icon) and Account Control is no longer invoked!  So, that problem has gone away.
May 25, 2017 May 25, 2017
Quick comment - today's Adobe updates have made no difference to this issue.
Those updates were Camera Raw and Lightroom. which does remind me.
Camera Raw has a Graphics Processor option. Sometimes it would leave black squares on images open in Photoshop even if Camera Raw was not being used. Unchecking that option fixed that problem. Could be ACR's graphics handling is taxing your GPU.
Might be worth a try, and I would recommend a restart of your PC to see if it helped.
May 26, 2017 May 26, 2017
Thanks for the suggestion – I tried it (with a restart) but no change in behaviour, I’m afraid.
Regards
Keith
