2 Replies Latest reply on May 17, 2017 8:24 AM by DobeyTime
    How to bulk remove the same image from multiple PDF's
    DobeyTime Level 1
      I was wondering if it is possible to remove a logo from a few hundred PDF's. These individual PDF's are all one page (product labels), however the location of the logo is in slightly different locations on some of the labels.  It is the same logo with the same JPEG name all instances. I am using Adobe Acrobat Pro DC 2015 Release (Classic), Version 2015.006.30306.
      Thanks.
        • 1. Re: How to bulk remove the same image from multiple PDF's
          try67 MVP & Adobe Community Professional
          That's not possible to do with Acrobat. The original file-name is gone when you convert the file to a PDF, and if the images are not in the same location then there's no way of identifying where they are and removing them. It might be possible to do using a custom-made plugin or stand-alone application, but those are quite complex to develop.
          1 person found this helpful
          • 2. Re: How to bulk remove the same image from multiple PDF's
            DobeyTime Level 1
            Thanks for the reply.  I do have another set of documents where the logo is in the same location, in all documents, but only on the first page (no logo on pages 2 through end of document).  The documents are varying in page amounts, but again it is only on the first page. In this instance, would it be possible to place a new logo over the old?  I would also be looking to have this change as a bulk update, rather than individually modifying the PDF's.
            Thanks.
