1
Photoshop Javascript change layer color
May 15, 2017 May 15, 2017
Hello I am writing scripts to automate Adobe Photoshop process. I am using JavaScript as my scripting language.
I've never used JavaScript in photoshop environment and i was wondering if someone could offer me some advice.
Here is a high level overview of what i am trying to accomplish.
  1) Get a data set from a JSON file
  2) Loop through the JSON file and pull data which will then be passed into the image layers
  3) Apply patterns and colors to each layer
4) Save file
The first 2 steps are relatively simple (basic javascript patterns) How ever where i start to run into trouble is when i am actually trying to manipulate the image in the photoshop.
How would I change the color of a layer ?
Here is my code snippet that is NOT working
          function changeColor(){
            var class2hex = app.activeDocument.artLayers.getByName("CLASS2HEX");
             alert(class2hex.kind) // LayerKind.SOLIDFLL
              var Color = new SolidColor();
             Color.rgb.hexValue = 'a5142f'';
              // HOW DO I APPLY THE COLOR TO THE LAYER?
               // ALSO how would i change the layer pattern in a similar fashion ?
Thank you!
Actions and scripting
3.7K
Adobe
Contributor ,
May 16, 2017 May 16, 2017
var docRef = app.activeDocument;
//displayDialogs = DialogModes.ALL
// define your fill color
var color = new SolidColor();
color.rgb["hexValue"] = "7f7f7f";
var  monCalc = app.activeDocument.artLayers.getByName("CLASS2HEX");
docRef.activeLayer =  monCalc ;
for ( j=0;j<docRef.layers.length;j++) //masquer tous les calques
            docRef.layers.visible=false;
monCalc.visible=true;
var moncalc2 = monCalc.duplicate();//conserver le texte original
pixeliser();//Transformer le calque texte en calque simple
//Rogner
docRef.trim(TrimType.TOPLEFT, true, true, true, true);
//var class2hex = app.activeDocument.artLayers.getByName("CLASS2HEX");
//             alert(class2hex.kind) // LayerKind.SOLIDFLL
for ( j=0;j<docRef.layers.length;j++) //Demasquer tous les calques
            docRef.layers.visible=true;
moncalc2.visible=true;
// perform select all & fill the document
// monCalc
docRef.selection.selectAll();
docRef.selection.fill(color);
docRef.selection.deselect();
function pixeliser()
var idMk = charIDToTypeID( "Mk  " );
    var desc165 = new ActionDescriptor();
    var idnull = charIDToTypeID( "null" );
        var ref14 = new ActionReference();
        var idSnpS = charIDToTypeID( "SnpS" );
        ref14.putClass( idSnpS );
    desc165.putReference( idnull, ref14 );
    var idFrom = charIDToTypeID( "From" );
        var ref15 = new ActionReference();
        var idHstS = charIDToTypeID( "HstS" );
        var idCrnH = charIDToTypeID( "CrnH" );
        ref15.putProperty( idHstS, idCrnH );
    desc165.putReference( idFrom, ref15 );
executeAction( idMk, desc165, DialogModes.NO );
