I just noticed that shadow and highlight recovery works in a 10% output on 5d mkiv camera. It seemed to gentle recovery for what I was used to. So I compared it with old 5d mkII and it was night and day - meaning shadow and highlight recover works in full power (makes a bit change to image) on shots taken with 5d mkII.
Anyone knows what the issue might be??
All images are RAW.
Hi mitjak,
Are you facing this issue after the last update or since the beginning? also, you may try to calibrate the monitor profile back to defaults and check if that helps.
Mohit
Hi mitjak,
Mohit
