Hello Friends,
I have a extension that is working in Illustrator CC version 2015 (version 19.0 , 19.0.1 , 19.1.0 , 19.1.1 , 19.2.0 , 19.2.1 ) .It is working for all these version
which is mention.
But This extension is not working for Illustrator version 20.0 and 20.1 and with later version.
I mentioning my manifest.xml file below which comes inside CSXS folder.
version inside manifest is mention below....
Please check version mention inside manifest is correct ?
Please assist me .
Regards
Kundan
Your manifest.xml seems to fine.
Are you set PlayerDebugMode for CSXS 7?
Thanks for reply Ten A,
Yes I set it to 1.
after that it's not working .
Can you show me more ditail of manifest.xml?
Please find the manifest
Unfortunately, Illustrator CC2015.3 or later version not supports Flash based Extensions.
Thanks for reply TenA.
Is there any option to load Flash based extension in Illustrator ?
Regards
Kundan
Hello TenA,
You may be correct but in Adobe document guide there is no any notification like that.
see here
There seems no way bcause of flash runtime removed.
