Javascript API for premiere pro
May 16, 2017 May 16, 2017
Where i can find the javascript API link for Premiere pro. I want to change the Lumetri color parameters like Exposure, Contrast, HIghlights, Shadows, Whites, Blacks and Saturation etc programmatically.
Nehru
SDK
10.0K
Enthusiast , May 17, 2017 May 17, 2017
The four best resources I'm aware of for exploring the Premiere Pro ExtendScript API follow:
  1. The ExtendScript Toolkit's Object Model Viewer - A built-in documentation browser that displays some of the available application APIs. Unfortunately, it's a bit out of date and does not contain any documentation for Components.
  2. The PProPanel api_doc.html page - This is the only resource I'm aware of that provides actual documentation for some of the Premiere Pro ExtendScript APIs. Unfortunately, it is an
Engaged ,
Hey Nehru,
As has been explained, there is no "JavaScript API" there is an ExtendScript API for interacting programmatically with Premiere, and the functionality for getting and setting keyframe values within Effect components is demonstrated in the PProPanel sample
Javascript API to change Premiere Pro Lumetri color
Basically, you have to navigate through the active sequence to select the target clip, within the clip to select the target component (eg Lumetri Effect), and within the component to select the target property (eg Exposure etc)
so a particular property (eg Exposure, Contrast, Highlights ect) would be referenced using something like:
myEffectProperty = app.project.activeSequence.videoTracks.clips.components.properties
where 'i' is the target track's index number (within the sequence)
where 'j' is the target clip's index number (within the track)
where 'k' is the component (effect) index number (within the clip)
where 'l' is the property index number (within the effect)
A quick scan of a targetted clip (using code derived directly from the PProPanel sample) reveals the following parameters (properties) for a Lumetri Color effect.
var clipComponents = clip.components;
if (clipComponents){
      for (var cc = 0; cc < clipComponents.numItems; ++cc) {
            $.writeln('component ' + cc + ' = ' + clipComponents[cc].matchName + ' : ' + clipComponents[cc].displayName);
            var componentProperties = clipComponents[cc].properties;
            for (var cp = 0; cp < componentProperties.numItems; ++cp){
                  $.writeln('param ' + cp + ' = ' + componentProperties[cp].displayName);
component 2 = AE.ADBE Lumetri : Lumetri Color
param 0 = Blob
param 1 =
param 2 = Basic Correction
param 3 =
param 4 =
param 5 =
param 6 = Input LUT
param 7 = HDR White
param 8 = White Balance
param 9 = WB Selector
param 10 = Temperature
param 11 = Tint
param 12 =
param 13 = Tone
param 14 = Exposure
param 15 = Contrast
param 16 = Highlights
param 17 = Shadows
param 18 = Whites
param 19 = Blacks
param 20 = HDR Specular
param 21 =
param 22 =
param 23 =
param 24 = Saturation
param 25 =
param 26 = Creative
param 27 =
param 28 =
param 29 =
param 30 = Look
param 31 = Intensity
param 32 = Adjustments
param 33 = Faded Film
param 34 = Sharpen
param 35 = Vibrance
param 36 = Saturation
param 37 =
param 38 = Tint Balance
param 39 =
param 40 =
param 41 = Curves
param 42 =
param 43 = RGB Curves
param 44 = HDR Range
param 45 =
param 46 =
param 47 = Hue Saturation Curves
param 48 =
param 49 =
param 50 =
param 51 = Color Wheels
param 52 =
param 53 = HDR White
param 54 =
param 55 =
param 56 = HSL Secondary
param 57 =
param 58 = Key
param 59 = Set color
param 60 = Add color
param 61 = Remove color
param 62 =
param 63 =
param 64 =
param 65 =
param 66 =
param 67 =
param 68 =
param 69 = Refine
param 70 = Denoise
param 71 = Blur
param 72 = Blur
param 73 = Correction
param 74 =
param 75 =
param 76 = Temperature
param 77 = Tint
param 78 = Contrast
param 79 = Sharpen
param 80 = Saturation
param 81 = Saturation
param 82 =
param 83 = Vignette
param 84 =
param 85 = Amount
param 86 = Midpoint
param 87 = Roundness
param 88 = Feather
param 89 =
param 90 = SpeedGrade Custom
param 91 = Custom Layer
param 92 = unused
param 93 = unused
param 94 =
param 95 =
param 96 =
param 97 = Embedded LUTs
Cheers
Andy
Enthusiast ,
  2. The PProPanel api_doc.html page - This is the only resource I'm aware of that provides actual documentation for some of the Premiere Pro ExtendScript APIs. Unfortunately, it is an html page and is best viewed by cloning the repository locally and opening the page in a browser.
  3. The PProPanel Premiere.jsx script - Bruce Bullis​ has consistently directed users to reference this sample code for insight into the Premiere Pro API. Advancements have been made (see #2 above), but, sadly, the most common suggestion is to reference this document.
  4. The Property Explorer Addon - A free utility provided by a community member that allows you to investigate APIs (properties and methods) at runtime from within the running application (e.g. Premiere Pro). As this utility uses a combination of ExtendScript Reflection and basic JavaScript property enumeration​ at runtime, it is capable of revealing APIs that are not documented in any of the aforementioned resources. Note that it may require special installation.
I hope this is helpful for future developers similarly struggling to find their bearing in this development environment!
Adobe Employee ,
One new, additional resource = Bryson Michael has put together an online API reference! http://www.brysonmichael.com/premiereapi-home
Enthusiast ,
Where did Bryson get the documentation? Some APIs listed there are undocumented in the resources I previously mentioned while others that are documented (e.g. in api_doc.html) don't have any descriptive content.
Adobe Employee ,
Personal experience? He didn't have access to anything that isn't already available.
Broadly: Yes, we realize that more documentation could make getting started, and helping yourself, easier. We stopped counting "PPro panels in active use, every day" once we got past 250; we don't think the lack of further documentation is preventing necessary integrations.
Until recently, we have focused on working code examples, over documentation work. That has changed.
Actually, for many development tasks, we've been told that screencasts walking through common tasks are more useful, than written instructions for moving doing the same things. My team and I are working on screencasts, and development heuristics (how to address commonly-requested tasks).
In the mean time, continue to feel free to ask us anything. We want all integrations to be successful.
Enthusiast ,
Addendum #1 - QE DOM
I should quickly add that certain APIs are 100% hidden from all of the resources I mentioned above. One major hole in the documentation is the QE DOM. According to Bruce Bullis​​, the QE DOM is "officially unsupported, and not recommended".
That said, certain important functionality is simply impossible without it. While at odds with the above statement, the much recommended official Premiere.jsx file makes use of it 6 times (at time of writing). In short, to make use of it, you must first run the following hidden API:
app.enableQE();
Running this function will insert a global qe object into the ExtendScript context, providing you with access to a large list of features (some of which are used in the Premiere.jsx file). The inserted object is a raw JavaScript (or ExtendScript) object, so it does not have a "Class" type associated with it.
Addendum #2 - Accessing the Object Model Viewer
I only just found this link, but I recommend checking it out for learning how to access the ExtendScript Toolkit's Object Model Viewer (#1 in the resources previously mentioned).
