Since installing Lightroom CC 2015.10 I've ad more problems than solutions.
Now I can't import new videos, I get an error:
An unknown error occurred while reading the video file, connecting to dynamic link server failed (1)
GORP3456.MP4
I also can't play previously imported videos.
How do I contact Adobe support directly?
Hi SherwininAustin,
Might try uninstalling and reinstalling the QuickTime from your machine also, you can refer the below discussion.
Import Error: Connecting to Dynamic Link Server Failed
Let us know if that helps.
Mohit
Mohit, thanks for your input, but I don't understand what QuickTIme would have to do with importing and playing a video file in Lightroom. I briefly looked at the discussion you mentioned, and not sure if it really helped that person Also, their problem was before LR CC 2015.10 became available. My system worked fine until I installed this latest version yesterday.
Any idea how to contact Adobe directly?
You can contact the support team via support link also, you may try and rename the dynamiclinkmediaserver folder and check if that helps.
Windows: documents >adobe >dynamic link
Mohit
Well I renamed the folder as you suggested. (added OLD to the folder name). When trying to play a previously imported video, it wouldn't even display the play bar that appears when you are in Loupe view mode.
When trying to import, the same error still occurs.
Upon inspection of this folder there are three subfolders labeled respectively 6.0, 7.0, and 10.0 all of which appear to be empty.
Any other thoughts?
Hi Mohit, I haven't heard back from you. Any ideas of what else to try or how to report this issue to Adobe?
Hi Sherwin_in_Austin,
You can contact the support team and they should remote in your machine and check the problem also apply all possible fix to the issue.
Mohit
How would I do that, there's no phone number listed for Lightroom support. If there was I would have tried that last week.
