Hello Friends,
I have a extension that is working in Illustrator CC version 2015 (version 19.0 , 19.0.1 , 19.1.0 , 19.1.1 , 19.2.0 , 19.2.1 ) .It is working for all these version
which is mention.
But This extension is not working for Illustrator version 20.0 and 20.1 and with later version.
I mentioning my manifest.xml file below which comes inside CSXS folder.
version inside manifest is mention below....
Please check version mention inside manifest is correct ?
Please assist me .
Regards
Kundan
You can normally keep the C++ plugin code the same when you change the extension from flash to html5.
Try changing the host version to:
<Host Name=”ILST” Version=”[18.0,21.9]” />
Thank you,
I am trying .
Regards
Kundan
Hello LeoTaro,
I tried but it didn't work.
From scripting forum I got to Ten A , the Flash based extension is not supporting by Illustrator CC version
20 and later version , Is it correct ?
Please find it .
Regards
Kundan
Yes flash based extensions are not supported in CC 2015.3 or later. You need to use html5 or a third party solution.
So I have to leave the attempt with flash based extension. ?
If I will change the extension as html5 , then I have to change the plugin code (vc++) also ,
according to html5 or the code will be same ?
Regards
Kundan
Thank you,
I am changing it into html5 , I will update you .
Regards
Kundan
