I'm using Premiere Elements 15 and would like to know if it is possible to change the aspect ration of pan and zoom from 16x9 to 1x1? I have a square album cover that I'd like to shrink (zoom out) so I can add text next to it.
This is not possible, if you are using the Pan & Zoom tool.
The tool will use the aspect ratio of your project.
You can manually keyframe that effect.
Manually keyframe at a different aspect ratio?
You can keyframe the crop and the Motion Properties.
Yes but not aspect ratio it seems.
I'm not quite clear what you're looking for, Mikey.
If you've got a 16:9 video, how can your scaling and position keyframing (pan and zoom) create a video that is other than 16:9?
