I'm having a problem with my composition panel, or with my computer. This is just an image of trees. But then AE cuts it into pieces (only when I'm working, after my export it's just an image of trees again). If I set the preview resolution lower, the effect becomes less. On 1/4 it's gone. When I zoom in it disappears too (on 50% it's gone). I don't know for how long I'm having this now. Is it fixable?
Chris
I'll bet this problem goes away if you go into your preferences and untick the option to use hardware to accelerate panels.
Flush your caches, update your graphics drivers.
Mylenium
you can also try to open your project settings and under "Video Rendering and Effects" choose the setting for "Mercury Software Only" if you want to verify that it's not an issue your GPU.
Thnx that solved the problem!
Chris
Hooray! I'm glad it worked. Please file a bug here​ so that Adobe can be made aware of the problem.
