List functions: Comparing lists... in SQL statements?
Participant ,
Sep 21, 2008 Sep 21, 2008
Hello
I got a table with a column containing comma-separated values, p.e.
row 1: 45,67,2,90,67
row 2: 34,7,23,9,7
row 3: 4
row 4: 567,8,90
now I would like to find the rows containing p.e. 4 and 90. the search input comes in a list 4,90
my results should be row 1, row 3 and row 4.
how do I write the WHERE clause in SQL?
thank you so much for hints...
Advanced techniques
372
Participant , Sep 22, 2008 Sep 22, 2008
Dear Dan, dear Kronin555
I'm sorry about saying that I wasn't able to fix my data model. After sleeping a night over and dreaming about it, I changed the model as you guys suggested and it works fine.... I didn't understand right away what you meant!
Be sure I will show up again with many stupid questions :-)
So, many thanks for your inputs.
Normalize your database and you won't have problems like this. If you didn't understand the 1st 3 words, I have heard good things about the book, Database Design for Mere Mortals.
Participant ,
You are right, I have no idea what 'Normalize your database' means! But actually my project is at a state where I don't touch the database design any longer. So unfortunately your input doesn't help much....
But thx anyway
Advocate ,
As Dan alluded to, you need to fix your data model. However, you say you can't do this, but you ask: "how do I write the WHERE clause in SQL?"
SQL isn't designed to help you continue to use a faulty data model. Thus, there isn't a nice way to write what you want, and it's going to be dog-slow.
For each item in the list you're searching for (4,90 in your example), you need to check 4 options:
Is this element at the beginning of my list? WHERE row LIKE '#element#,%'
Is this element at the end of my list? WHERE row LIKE '%,#element#'
Is this element in the middle of my list? WHERE row LIKE '%,#element#,%'
Is this the only element in the list? WHERE row = '#element#'
You can see how this gets crazy.
<cfset listToSearchFor = "4,90">
<cfquery ...>
SELECT * FROM tablename WHERE
<cfloop list="#listToSearchFor#" index="idx">
row LIKE '#idx#,%' OR
row LIKE '%,#idx#' OR
row LIKE '%,#idx#,%' OR
row = '#idx#' OR
</cfloop>
1 = 2
</cfquery>
All of these OR LIKE checks are gonna make the query slower and slower.
In the future, never EVER store a comma-delimited list in a database field. You want to break it out into another table. How do you do that? I'm glad you asked... In your example, where Row 1 = "45,67,2,90,67", assume the primary key for that row is "12"...
Main_Table
id
Whatever_Table (You'd name this table based on what these ids stand for in the row list)
main_id foreign key references main_table(id)
whatever_id
So your Main_Table would have an entry with an ID of 12 and Whatever_Table would contain:
main_id whatever_id
12 45
12 67
12 2
12 90
12 67
Now you can get all the whatever_id values for a given main_id by:
select whatever_id from whatever_table where main_id = 12;
And to answer your original question, you can do:
SELECT Main_Table.* FROM Main_Table JOIN Whatever_Table ON (Main.id = Whatever_Table.main_id)
WHERE whatever_id IN (4,90)
Lots easier, huh?
Participant ,
Documentation
