So when I open a Jpeg and the first and the only action that I do is Crop after which I immediately proceed to Save As ----> and later save it as another Jpeg named "2.1" or "3.1" or "5.3" or whatever Photoshop views everything after the "." as an extension so what ends up happening is I end up with an unreadable file name "2" with an extension of ".1" and not "2.1.jpeg" as I intend it to be. Is that a bug? Or am I doing something wrong? (Now what I do is I just save it "blah", and then go back and change the name to 2.1, 3.1, 5.4, 7.6 etc. etc. in the folder. but it's very inconvenient). Please help!
Things work that way in many apps, perhaps most of them. Windows is designed that way, perhaps Mac OS too. If you type a dot, it means you're taking charge of the whole name, including the file type. So if you want to save something with a dot in the name, type the file type. Not just file.1 but file.1.jpg or whatever you want.
Thanks. yeah that makes perfect sense, but I wish there was another way like an option or a box to check. but oh well. thanks again. I guess ill just use dashes or comas then.
Yeah, this catches me often. I can't tell you how often I've saved a music file (with a running time in the name) called something like "remix 3.15" instead of "remix 3.15.mp3".
Not sure of your OS, however many consider it bad practice, however it does not usually create issues on modern OS versions.
Links:
Naming Files, Paths, and Namespaces (Windows)
filesystems - Should file names contain multiple periods? - Super User
In Windows, set Folder Options to show extensions (they're hidden by default). Then I think it should work - otherwise everything after the last dot is treated as a file extension.
But why not use an underscore instead?
I find that doesn't help (though it makes the problem more evident).
