i have After Effect cc 2015, and Switches Column is not working, i can't press on any of the options!
can any one tell me why is that?
Thank you in advance
So, you try to click on motion blur, and it won't activate?
What, exact, version number of CC 2015 are you using? (Should be something like 13.x.x).
What OS?
yes, it wont activate, non of them is working
version 13.5.0.347
dahliaq34897861 wrote
version 13.5.0.347
That is the buggiest version of After Effects I have ever used. At the very least, you should update to 13.7.x, but I would highly recommend the latest version (14.2.x). It has way fewer bugs and is significantly faster to render many things compared to the version you're using.
When you give screen shots you should give them of your entire interface. I'm betting you have the hand tool selected.
it is the selection tool
Hi dahliaq34897861,
Still seeing this issue after updating the application?
Kevin
